EFI Problems - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-30-2006, 08:12 PM   #1 (permalink)
fatkid's Avatar
Member # 4862
EFI Problems
Started my 85 toy truck this morning to go to work, noticed the check engine light was on. While driving the truck, it has very little power and used nearly a quarter tank of gas to do 25 miles. Put the jumper in to check for trouble codes and the It reads nothing, in fact the light stays lit, no flash code whats so ever. Next I tried disconecting the O2 sensor to get a flash code and still nothing, light still will not go out. No idea whats going on, did some searching but didn't see anything like it.
Any ideas would be very helpful.
fatty
fatkid is offline   Reply With Quote Quick reply to this message
Old 05-30-2006, 09:02 PM   #2 (permalink)
Grim Reaper's Avatar
Member # 6726
That sounds like a smoked ECU.
If the ECU is good it should give you the code one to let you know ECU is able to give diagnostics.
Disconnect the battery and pull it out and check it for liquid damage.
[COLOR="Black"]Did you expect to find something deep and meaningful here?[/COLOR]
"He has all the virtues I dislike and none of the vices I admire." -- Winston Churchill
Grim Reaper is offline   Reply With Quote Quick reply to this message
Old 05-30-2006, 09:30 PM   #3 (permalink)
fatkid's Avatar
Member # 4862
Will a smoked ECU still allow the truck to run? and function well enough to drive?
I
Old 05-30-2006, 09:46 PM   #4 (permalink)
2stroke's Avatar
Member # 8981
did ya short the correct wires?
2stroke is offline   Reply With Quote Quick reply to this message
Old 05-30-2006, 09:51 PM   #5 (permalink)
fatkid's Avatar
Member # 4862
I thought I did (small yellow round two port plug), to make sure Desertoy came over and he did the same thing I did. I also tried with the other small odd shaped plug next to it to make sure I haven't totally lost my mind.
Old 05-30-2006, 09:53 PM   #6 (permalink)
2stroke's Avatar
Member # 8981
did ya disconnect the battery and start over to reset everything?
Old 05-30-2006, 09:57 PM   #7 (permalink)
fatkid's Avatar
Member # 4862
Did that too.
I've never even heard of the check engine light staying on like this before, anyone ever seen this?
Old 05-30-2006, 09:58 PM   #8 (permalink)
fatkid's Avatar
Member # 4862
Just to make sure the jumper wasn't fawked up I made several jumper wires to do the short and they all had the same result.
Old 05-31-2006, 12:00 AM   #9 (permalink)
fatkid's Avatar
Member # 4862
Checked to see if the EGR was working, pulled it off cleaned it and put vacume to it. Works fine, put it back on nothing changed. Could a TPS be make the check engine light stay on instead of flashing a code?
Old 05-31-2006, 05:41 AM   #10 (permalink)
Member # 6726
Nop TPS would give a flashing code.
Check the grounds to the body of the truck.
Old 05-31-2006, 10:50 AM   #11 (permalink)
flaash's Avatar
Member # 14557
this is where you are wrong a mis adjusted or ad tps may allow a check engine light to not function properly...usually it wont come on at all when the pins are shorted if the tps i outta whack...
TINBENDER
Suzuki Samurai powered tube buggy.:grinpimp:
Tow rig 2005 F-350,
[QUOTE=DRM;12804141]Really? Then how about you explain what "I am missing" by not shoving my tongue up my wife's ass. No, really... I'm dying to know what exactly *I* am supposed to get out of that.[/QUOTE]
flaash is offline   Reply With Quote Quick reply to this message
Old 05-31-2006, 11:10 AM   #12 (permalink)
Member # 6726
Then unplug the TPS once its started ..no shorted pins and it will idle with the TPS unplugged.
Old 05-31-2006, 12:17 PM   #13 (permalink)
flaash's Avatar
Member # 14557
almost any vehicle will idle with the tps unplugged it is written in their program to figure out a way to run with no tps input
TINBENDER
Tow rig 2005 F-350,
Old 05-31-2006, 01:23 PM   #14 (permalink)
Member # 6726
And if you read the complaint the light is on when jumped with no flashes....so your argument with me still has no merit to the problem the truck has.
If unplugging it does not change the symptoms then the problem is somewhere else or do you want to argue about that as well?
Offer the guy something to try with a valid reason or STFU.
BTW...the first thing the FSM says for these symptoms is inspect the harness for shorts. The second thing is says is try a different ECU. Since the truck was fine when parked chances are, unless and animal chewed up the harness, that the harness is good.
What ever happened is a result in a circuit failing when powered (spiked) or there is a power problem. Since he has a light at all we know the body (where the ECM is mounted) is getting 12v. Now a dropped ground due to corroded battery terminals or rust to the body might then let the ECM pull a ground through the sensors, running lights and injectors and sort of work BUT it would probably have some real issues if it was pulling ground from anywhere but the body.
Old 05-31-2006, 02:26 PM   #15 (permalink)
flaash's Avatar
Member # 14557
how about you go fuck yourself...for one i have been on the phone with him a couple times and offered him better solutions than the shit you are pulling out of your ass..thankyou and fuck off...
i was just correcting your innaccurate solutions....if you want to questioin what someone knows you should know if they are knowledgeable in the workings of vehicles which i am seeing as how i am a smog tech master certified . and i have been offering him solutions that i know from experience....and i dont think the body would be getting 12v seeing as it is a ground no a power supply the check engine light is getting 12v and ground seeing as it is on.... and further more just unplugging the tps to see if anything changes doesnt tell you if there is a problem there or not....
TINBENDER
Tow rig 2005 F-350,
Old 05-31-2006, 03:30 PM   #16 (permalink)
flaash's Avatar
Member # 14557
by the way fatty did you remember to check you canuter valve and muffler bearings?????????????
TINBENDER
Tow rig 2005 F-350,
Old 05-31-2006, 05:26 PM   #17 (permalink)
Member # 6726
hehehe what a tool. So I suppose you are a ASE certified tailpipe sniffer?
My credentsial....about as good as yours unless you pull up factory toy tech and a ASE certificate.....I'm also referencing a 85 FSM.
It gives no codes...till it gives codes you are getting nowhere.
If resetting and unplugging the The TPS or the AFM doesn't get it reading codes then one by one you have eliminated anything that could give that symptom short of the harness being chewed up or the ECM. The rest of the sensors work on a ground reference and they could all be dead short to ground or open and you would get codes but not a solid light.
.....Fastest thing to do is find somebody with a 85 or 86 (87 and newer is a different system and not interchangeable) and stick the ECM in their truck and see if it starts acting right.....
My bet...ECM is tits up. Like my My first post said.....Solid light is not a good thing or a normal thing. You yourself pointed out a shorted harness or TPS is more likely to lock the light out not give it a solid light.
Old 05-31-2006, 05:52 PM   #18 (permalink)
fatkid's Avatar
Member # 4862
Thanks for your help guys, until I get my junk running I'm going to be trying whatever it takes to get this thing fixed.
Old 05-31-2006, 06:06 PM   #19 (permalink)
fatkid's Avatar
Member # 4862
I have a 89561-14182 (84-4runner with A/T) will it work with my 85? Read the FAQ's and got mixed answers.
Old 05-31-2006, 06:20 PM   #20 (permalink)
flaash's Avatar
Member # 14557
master certified ase yes!!!!
Smog tech yes!!!!
ford factory trained yes!!!!!
Chevrolete factory trained yes!!!!!
Toyota factory trained still in the progress of taking classes but am partially factory trained!!!!!!!!
certified diesel tech
certified heavey equipment tech
transport refrigeration certified
do you want me to keep going!!!!!!
TINBENDER
Tow rig 2005 F-350,
Old 05-31-2006, 06:22 PM   #21 (permalink)
flaash's Avatar
Member # 14557
if there is a hard code the light stays on solid....no as far as not giving codes that is harder to track down....but you have to pick a starting point and mine would not be pcm....
TINBENDER
Tow rig 2005 F-350,
Old 05-31-2006, 06:23 PM   #22 (permalink)
flaash's Avatar
Member # 14557
cause if the pcm fried there would have to be a reason so why put another pcm in it to fry that one also with out checking out other things first???
TINBENDER
Tow rig 2005 F-350,
Old 05-31-2006, 06:24 PM   #23 (permalink)
flaash's Avatar
Member # 14557
Sorry the smog guys I met are some of the last people I would want working on my junk.
and this flow chart you posted up shows nothing of any value....
TINBENDER
Tow rig 2005 F-350,
Old 05-31-2006, 07:25 PM   #24 (permalink)
fatkid's Avatar
Member # 4862
Just pulled the ECM and I can hear shit rattling around inside, that can't be good...
Old 05-31-2006, 07:49 PM   #25 (permalink)
Member # 6726
Wait!
Is it the same size with the same plug configurations? 84 Carbs had a ECM under the passenger seat. 85 RE have a ECM in passenger kick panel....Not interchangeable if thats the under seat module.
Running that part number through Google pulls up reference to a 84 EFI BUT I was not aware or a 84 EFI on a truck...might be a cali model. I know 84 Cellicas ran EFI and that part number also matches the Celica.....I don't think it will work.
It looks like you want a 89530-35030 is what I find when looking for a 85.....doesnt specify if there is a AT or MT difference. I think their is a ECM for the AT mounted to the left side of the glove box on the side of the HVAC box.
