84 pickup wiring diagram - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-06-2006, 09:23 PM   #1 (permalink)
Member # 54883
Question 84 pickup wiring diagram
hey, im havin a problem with my 84 pickup. i keep blowing a 20 fuse everytime i back up then stop, it kills the signals, temp. guage and gas guage. does anyone have a wiring diagram for the truck they could send a picture of or know a link?? or if anyone has had the same problem that could gimme a few pointers, i bought 10 new fuses so im good for abit haha. oh and i have also ruled out turn signals, side markers, brake lights and backup lights as shorting out or what not. alright thanks guys
oh and if you have a picture of the diagram could you send it to kam_bc@hotmail.com thanks alot
kamyota is offline   Reply With Quote Quick reply to this message
Old 06-06-2006, 09:48 PM   #2 (permalink)
2stroke's Avatar
Member # 8981
got trailer wireing?
2stroke is offline   Reply With Quote Quick reply to this message
Old 06-06-2006, 10:19 PM   #3 (permalink)
Member # 54883
nope, has some tractor lookin back up lights mounted on the bottom but one is busted off and the other has the wire stripped off
Old 06-06-2006, 10:27 PM   #4 (permalink)
2manyprojects's Avatar
Member # 39901
Good place to start, clean that up.
Are you saying when the backup lights and brake lights are on together, it kills the fuse?
Try new bulbs. Sometimes the filaments are loose and cause funny things.
"]my 90 project [/URL]
Save a tree, eat a beaver.
There are two keys to life, leverage and lubrication. Sometimes you need both.
Because there is no 2nd chances on Pirate!
2manyprojects is offline   Reply With Quote Quick reply to this message
Old 06-06-2006, 11:00 PM   #5 (permalink)
Banned
Member # 56946
i remember seeing an downloadable 85 fsm somewhere...try a google searching it'll probably come up.
eightyfive is offline   Reply With Quote Quick reply to this message
Old 06-06-2006, 11:36 PM   #6 (permalink)
Member # 54883
hmm ok in my first post i lied, i think it has everything to do with the backups haha. usually it would let me back up abit ebfore diying but now 3 out of 3 times i only put the truck into reverse and i hear the fuse blow and my dash lights flicker then dim abit. so im pretty sure i have narrowed it down to the back up lights and those crappy extra abckups that are on it. any ideas from yuo guys what top check besides exposed cables bad ground and bulbs?? oh and thanks for the replies
Old 03-04-2011, 05:54 PM   #7 (permalink)
Member # 156762
84 toyota truck wiring diagram
Resurrecting a dead thread, but here goes - wonder if you ever found the 1984 Toyota truck FSM...
1984 Toyota xcab TDI conversion
truckeebiofuels is offline   Reply With Quote Quick reply to this message
Old 03-04-2011, 06:20 PM   #8 (permalink)
Member # 156762
1984 Toyota, Engine Control Module, Emission Control, 89550-35280, 22R, California
Looking for the pinout on 1984 Toyota truck, specifically for the ECM / Engine Control Module / Emission Control computer, PN 89550-35280, 22R, California version. Engine bay fuse and relay block diagrams would also be helpful.
I've looked throughout the Pirate Board, Yotatech, Toyota Nation, and elsewhere. There are manuals and pinouts for most Toyota trucks [I]but not the '84![I] I am looking at dropping $100 to get one, but I'm about there.
xxxtreme22r posted this, and it's very helpful. It doesn't match my truck 100%, I'm finding:
http://www.yotatech.com/f120/wiring-.../#post51670679
This is the 21 pin Emission Control Computer, PN 89550-35280 (22R, California):
This is the wiring harness for the 1984 Toyota truck's emission control computer, 21 pin:
This is the 21 pin harness interface:
Thanks , any help is really appreciated.
Old 03-04-2011, 06:38 PM   #9 (permalink)
Member # 78331
Best I got.
dirtchicken is offline   Reply With Quote Quick reply to this message
Old 03-04-2011, 07:03 PM   #10 (permalink)
Member # 156762
1984 Toyota Truck 22R FSM
dirtchicken, I've got the '85 FSM. It doesn't work for my '84. Perhaps it works for others' '84s...
There is this nice link to different Factory Service Manuals - many of '85 Toyota truck Factory Service Manuals online probably come from this site:
http://www.ncttora.com/fsm/index.html
There is the Toyota Tech Info System, but it's for 1990 Toyotas and later only.
https://techinfo.toyota.com/techInfo...m%2Findex.html
Maybe I'll be that guy who puts a 1984 toyota Truck-specific manual online after a day of scanning it all in...
Old 03-04-2011, 08:14 PM   #11 (permalink)
Member # 156762
Still looking for '84 Truck 21-pin ECM pin out
Here 's good info for an '85 4Runner, Engine Fuse Block detail:
http://www.4crawler.com/4x4/4R_TechI...tml#Electrical
It is not the same, though, as a 1984 truck's engine fuse block.
Here's mine:
Compare the differences. My '84 has the pink fuse (30A) and the yellow fuse is a 60A. The "Main" relay is the main engine relay (PN 9098704002) - those are perhaps the same, not sure. The relay that's labeled "CMH - Fuel Heater" (CMH = Cold Mixture Heater) on the '85 4Runner is (on my '84) relay PN 85931-354010, the emissions control relay.
I don't know if the CMH relay on the '85 Runner is the same as the '84 truck's emission control relay. I suspect not.
The smaller fuses are the same, I think.
FWIW...
Old 03-04-2011, 08:56 PM   #12 (permalink)
Member # 156762
22RE pin out & 22RTE pin out
http://www.diyautotune.com/tech_arti...oyota_22re.htm
Old 03-05-2011, 12:18 PM   #13 (permalink)
Mex-lego's Avatar
Member # 39351
I have a chiltons for 84-86 pickup and 4runner for about $26 and it has a very good wirering diagram for what I need. Any autozone, O'rilleys, or even amizon will have it. I would scan and send you a copy of the diagram but I am in the middle of the Ocean hunting for pirates and terrorist.
Mex-lego is offline   Reply With Quote Quick reply to this message
Old 03-05-2011, 02:41 PM   #14 (permalink)
Newbie
coyote577's Avatar
Member # 147297
here is a link to a 1994 FSM
http://cid-db24fad89707461c.office.l...px/toyota?uc=1
Give it a set of cohones, then baptize it in the mud,
pray to the rock gods, and wheel it till it croaks,
then resurrect it's bones, and drive it like its stolen.
Amen
____//,/___\,
[ _^ ____ ^ [oo]
()_)~o~()_ ()_)~o~)_)
coyote577 is offline   Reply With Quote Quick reply to this message
Old 03-06-2011, 12:02 AM   #15 (permalink)
Member # 154031
I'm gonna go out on a limb here and say there are subtle differences between a 84' and 94' Toy
[B][SIZE="4"][SIZE="5"]WatchThisFourwheelerz Vice Prez.......................[/SIZE][/SIZE][/B]
89'toyvolet is offline   Reply With Quote Quick reply to this message
