Oooooooooops! (turbo) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-19-2002, 09:57 PM   #1 (permalink)
DSI
DSI's Avatar
Member # 920
Send a message via Yahoo to DSI
well with all teh turbo stuff i've been reading this week i found several great articles on shimming hte waste gate actuator to gain boost, well i've also read how the CT20 is a lame turbo and not really capable of makign real boost... so why not remove teh actuator hose all together and plug it
i gotta say it sure sounded cool and accelerated faster than anything i've driven in a long time... but ummm, ya...
BOOM motor stalls and check eng light comes on! took my foot off the gas and she's back to life... dunno what it was but it scared the hell outta me!
5 8mm washer's is a gain over stock, but definatly not near as much ass as the removed actuator
according to the articles i'm pushing 10-11psi now
and i can bark 38's @ 8psi with a spool into second now
Thanks to the companies that make it happen: Bilstein Shock Absorbers, Trail-Gear, Trent Fab, PRP Seats, Raceline Wheels, PSC, MJ Motorsports
DSI is offline   Reply With Quote
Old 04-19-2002, 10:20 PM   #2 (permalink)
Member # 1070
Arrow
You gonna team up with SuperRunner to race the ricers now?
-Dan
Where is pancakes house?
dangerber is offline   Reply With Quote
Old 04-19-2002, 10:50 PM   #3 (permalink)
NIC
Member # 2150
Send a message via ICQ to NIC Send a message via Yahoo to NIC
your leaning it out to far.
NICK
someone who has everything has everything to lose. BEN HARPER
www.outerlimits4x4.com
NIC is offline   Reply With Quote
Old 04-19-2002, 10:54 PM   #4 (permalink)
Member # 3879
Re: Oooooooooops! (turbo)
I hope you're not going by articles and you're using a boost gauge. If you remove the vac line from the wastegate you should easily be able to make 20+ psi. If that's the case one hard rattle will likely be it's last, knock sensor or not. Not to mention it would be lean as hell.
-BTG Rockcrawlers-
Toyota 3VZE turbo
Benchworks steering systems in Az RIPPED ME OFF
Clifton is offline   Reply With Quote
Old 04-19-2002, 11:36 PM   #5 (permalink)
NIC
Member # 2150
Re: Re: Oooooooooops! (turbo)
Originally posted by Clifton
I If you remove the vac line from the wastegate you should easily be able to make 20+ psi. If that's the case one hard rattle will likely be it's last, knock sensor or not.
try that on a diesel engine and end up like me, a 4 month top to bottom rebuild.
NICK
Old 04-20-2002, 12:13 AM   #6 (permalink)
CRO
Member # 7588
To avoid a lean condition when the boost starts getting way up there you could install a pressure switch on your intake manifold set at around 10 psi that automatically switches on the cold start injector (basically bypassing the thermal switch in the front of the intake manifold) to add more fuel to keep it closer to stoich.
1948 Willys
1952 M37CDN Powag
CRO is offline   Reply With Quote
Old 04-20-2002, 12:34 AM   #7 (permalink)
crash's Avatar
Member # 1588
Good idea cro..
Mike Crash Kash
crash is offline   Reply With Quote
Old 04-20-2002, 01:12 AM   #8 (permalink)
Member # 10796
You should think about a new garett t3/t4 hybrid turbo. they go for about $450 at www.turbochargers.com new! also go for larger injectors.
The toyota CT20 is not a bad turbo, it just isn't great.
they are prone to cracking in the exhaust housing and
have limited flow when the engine is at high RPMs 5000+ but at mid rpm they will boost like crazy you could probably get 20+ psi.
if you want to add more power, think about adding an air to air intercooler. you could find one at a junkyard... with the intercooler your boost will be lower at the manifold but you will gain power because the air is more dense.
By far the most simple way to get more fuel to the engine is to install an adjustable fuel pressure regulator and crank up the fuel pressure... this will force more fuel through the injectors and help compensate for the extra boost pressure.
Careful with that engine... your stock pistons wont like extra boost, hot timing, and lean conditions... they will melt!!!
CWToyota is offline   Reply With Quote
Old 04-20-2002, 10:01 AM   #9 (permalink)
Member # 8933
Location: yellow house with toyotas in the yard, next door to the lesbians, down the street from the best Mexican food in Baja Torrance
If you need an intercooler, I have one from an Audi, cheep, give me a shout
I kissed her on the left cheek,
I kissed her on the right cheek,
But I left her behind for you.
r77toy is offline   Reply With Quote
Old 04-20-2002, 11:15 AM   #10 (permalink)
Member # 4733
Send a message via AIM to CRAZY MATT Send a message via MSN to CRAZY MATT Send a message via Yahoo to CRAZY MATT
might concider using a grainger valve to adjust ur boost settings
'80 Toyota '55 IH COE Truck '70 W100 4 Coots - '90 cummins 15 tractors
and still collecting
CRAZY MATT is offline   Reply With Quote
Old 04-20-2002, 12:50 PM   #11 (permalink)
Member # 4060
The motor shut down because you hit the boost limit set by the stock ECU. There is a way to jumper the ECU so this doesn't happen, but you are gonna blow holes in the top of the pistons at the boost level you're running now (too lean).
paddlenbike is offline   Reply With Quote
Old 04-20-2002, 02:52 PM   #12 (permalink)
DSI
DSI's Avatar
Member # 920
450 for a turbo 400 for a header, plus new exhaust to match it... Hmm sounds like over 1k to me to do it right, NOPE not what i want to do, sorry...
Old 04-20-2002, 08:30 PM   #13 (permalink)
Member # 9324
Send a message via AIM to T1H5_TA3 Send a message via MSN to T1H5_TA3 Send a message via Yahoo to T1H5_TA3
how about a boost compesating fmu? they dont cost that much, and wouldnt be that hard to adapt..
87 zuk 1.3, soa, 31's, spartan in rear
T1H5_TA3 is offline   Reply With Quote
Old 04-20-2002, 08:36 PM   #14 (permalink)
DSI
DSI's Avatar
Member # 920
hey Brian, care to elaborate some??
Old 04-20-2002, 08:54 PM   #15 (permalink)
crash's Avatar
Member # 1588
I think that means Fuel Metering Unit?
Mike Crash Kash
Old 04-20-2002, 09:04 PM   #16 (permalink)
DSI
DSI's Avatar
Member # 920
well than you elaborate einstein
Old 04-20-2002, 09:29 PM   #17 (permalink)
crash's Avatar
Member # 1588
well, the grass is green, the sky is blue, dirt is brown, and ashfault is black. Concreet is whiteish, your rig is, umm, blue, your %$$^&*& hole is large and black
Mike Crash Kash
Old 04-21-2002, 12:06 AM   #18 (permalink)
DSI
DSI's Avatar
Member # 920
you're so dead there widdleman!
