help with brakes on 1988 toyota pickup 4wd - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-18-2006, 08:53 PM   #1 (permalink)
Member # 79493
i have a 1988 toyota pickup EFI 4WD, i have a question on how to properly bleed the brakes. I just replaced the master cylinder with another oem one, I normally know how to do this type of procedure, but this ones got me stumped.....
first of all the rear drum brakes are both bleed but when i go to bleed the front disc breaks no fluid comes out when the pedal is pushed down.
second of all if it does have something related to bleeding the LSPV how do i do that properly?
i anyone can help that'll be great, and if it can be done without a mechanic that would be great also, since im a college student and dont have the funds....
abe02 is offline   Reply With Quote Quick reply to this message
Old 09-18-2006, 08:55 PM   #2 (permalink)
Member # 44388
basically you have to bench bleed the master or there will be an air bubble trapped in there that wont be bled out (the stroke is too short or something from the brake pedal) so take off the master- either get little plugs that fit in the brake line holes or better get a little dealio that recycles the brake fluid back into the reservoir as you pump it till no air bubbles come out- then you can bleed it like normal
ScottB is offline   Reply With Quote Quick reply to this message
Old 09-18-2006, 08:59 PM   #3 (permalink)
tanman2003's Avatar
Member # 19325
Bench bleed Master Cyl then
RR/LR/RF/LF/LSPV
tanman2003 is offline   Reply With Quote Quick reply to this message
Old 09-18-2006, 10:19 PM   #4 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
RR/LR/RF/LF/LSPV
This is wrong Longest to shortest then the LSPV
LR
RR
RF
LF
LSPV
And if you do not believe me, read the FSM!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Look at this hooky drawing, which is the furthest from the MC.
Old 09-19-2006, 12:27 PM   #5 (permalink)
Member # 5315
Make sure your bleed screws are not plugged up, maybe your bleed screws or calipers are just corroded and totally screwed up.
86 22R Weber carbed Toy Truck
Coop 50 is offline   Reply With Quote Quick reply to this message
Old 09-19-2006, 12:48 PM   #6 (permalink)
tanman2003's Avatar
Member # 19325
My bad i was physically thinking farthest away from the master cyl, not actually trough the lines.
Old 09-19-2006, 05:31 PM   #7 (permalink)
Member # 79493
thanks
i got it working.. the front lines had a bunch of crud and build up but now everything is all good...thanks for the help
