22r noise - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-22-2006, 01:24 PM   #1 (permalink)
22r
Member # 54816
22r noise
My 22r is doing some clicking noise... a bit of clicking noise at idle... and somtimes a BIG clicking noise at idle proportionnal to the engine speed... I think this clicking noise began after some 4500-5000rpm shiftings. It seems to be around the valve cover area... but maybe piston pins/ or piston slap? I checked the oil pressure when it's happened and it was at 1/8 of the original sr5 cluster gauge at idle. Do you think it's a too low oil pressure, or pistons? My compression is 190 all cylinders engine don't take oil, and.. oil level ok (10w40). Oh forget the most important thing... I adjusted the valves to specs 0.008 intake 0.012 ex... and it don't helped.
22r is offline   Reply With Quote Quick reply to this message
Old 09-22-2006, 02:31 PM   #2 (permalink)
Member # 1852
Send a message via AIM to dcg9381 Send a message via Yahoo to dcg9381
Original motor or Reman? Check the timing chain guides?
dcg9381 is offline   Reply With Quote Quick reply to this message
Old 09-22-2006, 04:35 PM   #3 (permalink)
22r
Member # 54816
115k miles original engine, timing guides ok. Oil pump at this mileage, is it possible?
Old 09-22-2006, 05:27 PM   #4 (permalink)
shamb's Avatar
Member # 22368
Are you sure the valves are staying adjusted? have you tried adjusting them, run it and then pull it off and recheck them once it starts making the sound again?
Knowledge is power
New Project in the works, 85' 4runner aka ?
R.I.P to ALL our brothers that have lost their lives doing what they love.
shamb is offline   Reply With Quote Quick reply to this message
Old 09-22-2006, 05:48 PM   #5 (permalink)
Member # 102
adjust your valves
brownbagg is offline   Reply With Quote Quick reply to this message
Old 09-22-2006, 08:30 PM   #6 (permalink)
22r
Member # 54816
i adjusted the valves to specs very tight and hot. Immediately after adjustment it still make this sound. Oil pressure at 1/10-1/8 of sr5 cluster warm idle is enough?
Old 09-23-2006, 11:40 AM   #7 (permalink)
shamb's Avatar
Member # 22368
no clue what that exact measurement is BUT i'd assume thats not enough oil pressure. Go buy a cheap mechanical oil pressure gauge and see what it reads. I'f its not around 25 at idle and 50 while on the gas then you probably need a new oil pump.
Knowledge is power
Old 09-24-2006, 09:08 AM   #8 (permalink)
Member # 4677
There are several things the make a "click" in a 22R. Valve lash, t-chain guides, exhaust leak, spark plug wire, and...... the fuel pump!!
Gnarls.
Gnarly4X is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 02:54 PM   #9 (permalink)
22r
Member # 54816
It's a mechanical "click", not an exhaust leak fuel pump or something like that... maybe timing chain, but the guides are ok... I have a 8deg slack on my t-chain, i checked it by positionning the crank at 0deg turning counterclockwise, then began to turn it clockwise, at 8 deg the rotor begins to move, is 8 degrees is too much slack? It's on a 115k miles engine (never rebuilt, 20 years).
Old 09-26-2006, 04:29 AM   #10 (permalink)
Member # 4677
This doesn't sound like your problem, but just in case, I should have been more specific.... a bad or failing fuel pump in a 22R will click loudly (mechanical) and sound similar to a loose t-chain, or a loose rocker arm. I've had two fuel pumps on my 85 22R do this. The first time, it drove me nuts for about a week before I isolated the noise. Piston slap is usually very short and at cold starts. I'd recheck the valve lash and try 7/11.
8 degrees slack at the crank may be excessive.
Gnarls.
