85 toyota frame repair? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-22-2006, 09:20 PM   #1 (permalink)
Member # 79696
I have a 85 Toyota 4x4 pickup and the rear frame decided to rot away on me. Is there a way to repair this kind of damage? Or is this when everyone decides to throw in the towel? The truck runs good and I would hate to send it to the scrap yard if there is a way to fix it.
GreenMeanie is offline   Reply With Quote Quick reply to this message
Old 09-22-2006, 09:35 PM   #2 (permalink)
Member # 73816
what the hell are you talking about this is when it gets fun
jimmyhats is offline   Reply With Quote Quick reply to this message
Old 09-22-2006, 09:40 PM   #3 (permalink)
Hendo's Avatar
Member # 20295
Send a message via MSN to Hendo
pics
Hendo is offline   Reply With Quote Quick reply to this message
Old 09-22-2006, 09:53 PM   #4 (permalink)
Member # 79696
I can maybe get PICS tommarrow. One side cracked right in half and they are in rough shape. Then I hope I can get some help from the pros here LOL.
Old 09-22-2006, 09:59 PM   #5 (permalink)
Member # 73342
Not hard to fix if the spots arent to bad/big'
t0talkos is offline   Reply With Quote Quick reply to this message
Old 09-22-2006, 10:15 PM   #6 (permalink)
Lowtorious's Avatar
Member # 2387
Send a message via AIM to Lowtorious
There have been several posts regarding frame repair. Some have replaced sections of framing including inner/outer walls or fabricating complete back half replacements. It's something's that definately doable but you have to see what you're working with first. You may not have good steel for several inches in either direction.
Lowtorious is offline   Reply With Quote Quick reply to this message
Old 09-22-2006, 11:27 PM   #7 (permalink)
Member # 69594
Depends, if you want to build a wheeler, it just involves a torch or sawzall, a welder and some tube.
Nothing happens when you die.
TrikeKid is offline   Reply With Quote Quick reply to this message
Old 09-23-2006, 12:02 AM   #8 (permalink)
toyota69N's Avatar
Member # 79494
u got bad frame
u send pics u maybe able to cut out and replace or use some type of box frame for it
toyota69N is offline   Reply With Quote Quick reply to this message
Old 09-23-2006, 11:27 AM   #9 (permalink)
Member # 79696
new england RUST!
Here is what new england does to toyotas.
The rust is pretty much spred threwout the rear frame it probably could use a complete replacement. If someone could point me to some links on frame replacement that would be great.
Old 09-23-2006, 12:18 PM   #10 (permalink)
Member # 66914
cut that shit off and cage the rear
1984 Toyota 4x4
GA86yota is offline   Reply With Quote Quick reply to this message
Old 09-23-2006, 12:47 PM   #11 (permalink)
Member # 12304
find one with front end damage and use the rear to repair yours
If I did it right I'm sorry I'll try to screw it up next time . Drive it rough and lets see whats snaps frist .
pipefitter is offline   Reply With Quote Quick reply to this message
Old 09-23-2006, 05:56 PM   #12 (permalink)
flimmy's Avatar
Member # 3101
Call BudBuilt
flimmy is offline   Reply With Quote Quick reply to this message
Old 09-23-2006, 06:00 PM   #13 (permalink)
Member # 79696
LOL it could have been.
I bought it with the wood bed on it. I ran it for 2 years before the frame shit the bed.
Originally Posted by flimmy
Call BudBuilt
Old 09-23-2006, 06:06 PM   #14 (permalink)
flimmy's Avatar
Member # 3101
LOOK
http://www.budbuilt.com/new/frames.html
Old 09-23-2006, 08:07 PM   #15 (permalink)
Member # 102
I took a perfect 84 frame to the landfill couple months ago
brownbagg is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 07:09 AM   #16 (permalink)
flimmy's Avatar
Member # 3101
He's in CT , he'll never find a good frame.
Old 09-24-2006, 12:13 PM   #17 (permalink)
Member # 30386
Send a message via AIM to 85xtracab
said but true. i live in CT as well, and i have an 85 frame went once we fixed it, i dont even drive in the winter, and its going again already. i am in CO for college now so im finding something new to build out here.
cut sections out and fix, or find a whole new rear. good luck.
86 xtracab
85xtracab is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 05:40 PM   #18 (permalink)
Member # 15945
I have one siting in my back yard, looking for a home.
weedwacker is offline   Reply With Quote Quick reply to this message
Old 09-24-2006, 06:17 PM   #19 (permalink)
Member # 46808
i have an 85 4runner, the frame was in great shape- mostly original paint until the rear most tube crossmember. after that the thinner inside boxing had a couple holes on each side. patching a rusty frame is a waste of time IMO, so i hacked it off 8" behind said crossmember. the closest tubing is 4"x2" which wouldn't work, so i had some 3/16" C channel formed up, 2 outside and 2 inside pieces. i also added a 2x3 tube crossmember at the back.
oh yeah, the whole process took about 8 hours solo, including beer breaks. started at midnight, finished in time for work in the morning. the truck is a DD.
if the rest of the frame is good, its worth it.
'85 4Runner, 3B diesel, marlin duals, OTT hysteer, Smurfields, Aussies, rears/chebbys, MTRs, winch, loose ends...
huckthehaus is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 10:23 AM   #20 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
That is when you build a new frame...
94 GMC 6.5TD K1500 Yukon SLE / 93 Chevy 6.5TD K2500
85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 09-25-2006, 03:29 PM   #21 (permalink)
Member # 30386
if you are looking for local parts you can try jonfund.com or the ne4roc.org forum. goodluck
86 xtracab
Old 09-25-2006, 03:31 PM   #22 (permalink)
Member # 30386
86 xtracab
