1984 sr5 4x4 fuel filter??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-09-2006, 03:05 PM   #1 (permalink)
Member # 49829
im haveing trouble finding my fuel filter on my 84 toyota 4x4, i have a chiltons manual and i shows everything from the 70 to 88 toyotas and has bad pictures and sometime none so i was wondering if someone has a picture of where it located or can assist me in some more help finding it. thanks ryan
also i cant seem to find the search button im trying to search thru the site but cant find search function.
agpicker is offline   Reply With Quote Quick reply to this message
Old 12-09-2006, 03:11 PM   #2 (permalink)
Member # 5333
Send a message via Yahoo to 5spd
If its Carbed, next to the gas tank....follow the lines, next to the rail. Lay under the truck & you will see it there.
If its an early EFI then under the intake manifold on the pass side of the motor.
5spd is offline   Reply With Quote Quick reply to this message
Old 12-09-2006, 03:14 PM   #3 (permalink)
Member # 49829
yeah its carbed and ill look again by the gass tank, thanks
Old 12-09-2006, 07:09 PM   #4 (permalink)
Member # 69751
Send a message via AIM to j2005 Send a message via Skype™ to j2005
its behind/mounted to the bed support post
j2005 is offline   Reply With Quote Quick reply to this message
Old 12-10-2006, 10:04 AM   #5 (permalink)
RRMike's Avatar
Member # 56886
x2
You will have to look up alongside the bed below the filler neck. It's not in front of the tank on the frame. It's on top of the frame on the front of the bed support in front of the pass side rear tire.
[QUOTE=RockStomper-Toy]What??? WTF does Ford have to do with anything in this post? Are you saying if you own a Ford then you're dumb? If so, you can go FUCK yourself and stick your head in a meat grinder :mad3:[/QUOTE]
RRMike is offline   Reply With Quote Quick reply to this message
