propane transfer pump - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-17-2007, 05:56 PM   #1 (permalink)
Member # 69751
Send a message via AIM to j2005 Send a message via Skype™ to j2005
just like the title says does any one have any idea on where i could get a LPG propane transfer pump. i have been told they are out there but i have no idea on where to get one. i got my truck converted and i would like to fill it up at home instead of driving 40 miles round trip to get propane.
thanks
j2005 is offline   Reply With Quote Quick reply to this message
Old 01-17-2007, 06:07 PM   #2 (permalink)
Member # 45085
I assume you already have a tank at home. If so, does it have an outlet on the bottom? If it does you can connect to the bottom outlet with a hose and just let the pressure of the propane push the liquid propane into your other tank. This is what we used to do.
82toycrawler is offline   Reply With Quote Quick reply to this message
Old 01-17-2007, 07:56 PM   #3 (permalink)
4CrawlR's Avatar
Member # 4716
Or try your local propane distrubutor, they should be able to set you up.
4CrawlR is offline   Reply With Quote Quick reply to this message
Old 01-17-2007, 08:12 PM   #4 (permalink)
Member # 69751
well no i dont have a valve on the bottom and the local shop said that a hand operated pump is around 500 his cost
Old 01-17-2007, 08:14 PM   #5 (permalink)
4CrawlR's Avatar
Member # 4716
Try this Google search
Old 01-17-2007, 08:28 PM   #6 (permalink)
Member # 18528
Send a message via AIM to BenMara
http://www.pplmotorhomes.com/parts/l...over-valve.htm
Function before Fashion
BenMara is offline   Reply With Quote Quick reply to this message
Old 01-17-2007, 08:53 PM   #7 (permalink)
Member # 69751
picked trough the google search and found nothing (i did find some GUCCI high heel pumps that my girlfriend would like) the change over valve looks interesting. i ma going to call about it tommorrow and see whats up.
thanks again
Old 01-19-2007, 05:42 PM   #8 (permalink)
Member # 69751
anyone
Old 01-30-2007, 02:38 PM   #9 (permalink)
Member # 69751
i checked the above mentioned ideas and they were a bust. any one else have any suggestions?
Old 02-09-2007, 03:50 PM   #10 (permalink)
Member # 69751
any one new that might know?
Old 02-09-2007, 03:57 PM   #11 (permalink)
Myanarchy's Avatar
Member # 14059
Hmm, we have abunch of propane tractors, and the propane comes straight out of a valve through a hose, into the tank. Vents pressure to allow the gas to flow, never done it anyother way
Jeeper89 is a bitch
Myanarchy is offline   Reply With Quote Quick reply to this message
Old 02-09-2007, 04:17 PM   #12 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
2nd post down on Roger's Google link:
http://www.bergquistinc.com/pumps.html
Krug Hand Pump
A simple piston hand pump for uses in filling portable and motor fuel cylinders. Six gallon capacity at 40 strokes per minute.
MT4Runner is offline   Reply With Quote Quick reply to this message
Old 02-09-2007, 04:19 PM   #13 (permalink)
Myanarchy's Avatar
Member # 14059
Krug Hand Pump
LOL, We just got one of those things from an estate sale and I had NO idea what it was
Thanks for clearing that up
Jeeper89 is a bitch
Old 02-09-2007, 04:21 PM   #14 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
Whatcha want for it?!
Old 02-09-2007, 04:29 PM   #15 (permalink)
Myanarchy's Avatar
Member # 14059
Apparently its useful now. We just converted my dad's project truck to propane
Sorry
Jeeper89 is a bitch
Old 02-09-2007, 04:40 PM   #16 (permalink)
NoBrainR's Avatar
Member # 250
Some tanks have both the liquid and gas valve on the top. The liquid valve has a dip tube inside the tank which goes to just off the bottom of the tank. It should be marked if your tank has one (right next to the fill and level guage).
Making good decisions comes from experience .......
...... experience comes from making bad decisions
NoBrainR is offline   Reply With Quote Quick reply to this message
Old 02-09-2007, 04:51 PM   #17 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
Ummm...actually, it's an old water pump.
Whatchou want for dat old water pump dere?
Did you use gotpropane, or forklift parts?
Old 02-09-2007, 04:53 PM   #18 (permalink)
Myanarchy's Avatar
Member # 14059
Got everything from the estate sale actually
have no idea what he payed for it, I'll ask cause I'm curious now
Jeeper89 is a bitch
