aftermarket headlights? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-31-2002, 02:02 PM   #1 (permalink)
Booger Weldz's Avatar
Member # 2931
some expanded metal, headligfht and turn siganl mounts and i should be good. are there DOT aftermarket headlights? id like 4- 2 low beam and 2 to join them in high beam, like an older vw GTI. ideas??
color="lime">
Ducati street fighter 1098s. Spoiled 1wd.
Booger Weldz is offline   Reply With Quote Quick reply to this message
Old 05-31-2002, 02:24 PM   #2 (permalink)
Member # 8682
Send a message via AIM to Chewbacca
Paul you may want to check out IPF lights, they make replacement headlights... www.arbusa.com
85 runner - ARBs, 4.88s, inchworm'd, 35 MT/R
Chewbacca is offline   Reply With Quote Quick reply to this message
Old 05-31-2002, 02:34 PM   #3 (permalink)
Member # 10229
Well - get a VW GTI setup
Heres a neat 90mm round "projector" setup.
DOT legal
http://www.susquehanna.com/susq/new.htm
Cibie has these cool 70's Mercedes VW GTI like lights but yellow
http://www.talbotco.com/e-code_lamps.htm
If yer made o money - HID
(And DOT legal)
http://www.sylvania.com/xenarc/prodinfo.htm
Or get a GM truck setup (but I think thats UGLY)
EWong is offline   Reply With Quote Quick reply to this message
Old 05-31-2002, 02:45 PM   #4 (permalink)
Member # 2931
eeek! those things are high dollar! are those 5 inch round lights at kragen, autozone street legal?
color="lime">
Old 05-31-2002, 02:55 PM   #5 (permalink)
Member # 10229
Well - genuine VW GTI
http://www.germanautoparts.com/
If yer looking at $5 lights....
Get buckets for an old skool 6024 (thats a 7" round) headlight.
Then headlights are cheap - and DOT legal (as a 6024 is a DOT beam - doh)
The only "Aftermarket" lights that would be DOT legal as headlights would probably be "snowplow" lights. Bolt em on and go.
The advantage of the snowplow lights - they have an integrated turn signal and clearance light.
Everything ya need to convince Officer Bob yer legal.
Northern has em I think.
Those typically use a 6054 beam. Those can be swapped for "e-code" beams when yer lottery ticket hits.
Old 05-31-2002, 03:09 PM   #6 (permalink)
Member # 5994
Go here and click on Neolight... cheapy VW GTI lights.
If you really want to save... go look through the euro car section at your local yard. Many 70's and early 80's cars were upgraded to H4 lights. Look for the heavily fluted lens and 'H' designation on lens.
Brian
Bjowett is offline   Reply With Quote Quick reply to this message
Old 05-31-2002, 04:08 PM   #7 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
DOT legal
(And DOT legal)
High dollar, you have never seen Paul drive, if it is there and he wants to go there he will no matter what the cost You could use Motorcycle headlights.
Old 05-31-2002, 04:52 PM   #8 (permalink)
Member # 2405
SEARCH!! yah faulker, I just asked the same question not even 3 weeks ago!! Did you even notice what I had for lights? If youd stop eatin them cheap mushrooms off that Oakey cow patties......
No really, I bought them Hella Lights, They dont have high beam, and I tried to hook up some H4 bulbls but they have different bulbs, so lately I havent found any high/low beam bulbs that fit em. But if you aim em right, you will have no problems runnin them on the street. Although if you want high beams then just get out and aim em up, then they are bright! In my opinion, it was a good choice, they are low profile, I think 5" round, and can be mounted anywhere, upside down, sideways, Im sure you can even Spoon em
Im buzzin. Its what I get for gettin off at 1pm. Ive got 5 hours on Yah
408_jigga is offline   Reply With Quote Quick reply to this message
Old 05-31-2002, 04:57 PM   #9 (permalink)
Member # 2405
Re: aftermarket headlights?
All that damage from my lil 1/2"wall auger bit for a rear bumper???? You should call that cage "Rocked_it_Bumper"
Old 05-31-2002, 05:17 PM   #10 (permalink)
SeaBass44's Avatar
Member # 40
Fawk Paul....poor fawkin truck I plan on going to a tube front grill, no fenders and some after market off-road lights, not leagal but I'll rig it so it seems so
# 530.532.4529
TTC 2010 1989 BRONCO
-Awesome web development for your business.
SeaBass44 is offline   Reply With Quote Quick reply to this message
Old 05-31-2002, 05:21 PM   #11 (permalink)
Member # 2405
Seabass its the only way to go. Unless your like me and want to do a replacment twice a year just so you can be "street legal" fuck that Im sick of bein street legal. Until I get a tow rig and trailer, Ill just rent a car dolly, put stock 28"s on it and tow it with my 86 fo bangah!
Old 05-31-2002, 05:29 PM   #12 (permalink)
SeaBass44's Avatar
Member # 40
R U going to be at Drew's run?
# 530.532.4529
Old 05-31-2002, 05:39 PM   #13 (permalink)
Member # 2405
At this rate? No!
But I got all summer.
Old 05-31-2002, 05:58 PM   #14 (permalink)
SeaBass44's Avatar
Member # 40
At this rate? No!
Does boggie have a seat 4 ya?......
# 530.532.4529
Old 05-31-2002, 06:11 PM   #15 (permalink)
RE:Todd's Avatar
Member # 422
Cool
I might have a seat. Actually, I got 4.
Paul, check on BugPack Part# 3530. It's a single post mount, 7" round headlight shell. That's what I plan on using with dual beam headlights.
Todd Steele
TINBENDERS
Formula Toy #006; Thanks to Deaver Spring, High Angle Driveline, Longfields, Rock Buggy Supply, PRP Seats, Marlin Crawler, Coast Motor Supply and RockStomper.
RE:Todd is offline   Reply With Quote Quick reply to this message
Old 05-31-2002, 06:15 PM   #16 (permalink)
Member # 2405
Paul can sit on my lap. I dont care.
Im there. Drunkin or not!!
Old 05-31-2002, 06:44 PM   #17 (permalink)
Member # 2798
paul do us all a faver and take the fawking body off!!!! and we will make a street legal buggy that way when the second vioce in you head tells you to go for it ( 18' high wall) you can!!!! drive it over to dustins and let the imagination take over
Cliff
go marlin........... dont trust dishonest vendors that lie to you and play games
e cliff is offline   Reply With Quote Quick reply to this message
Old 05-31-2002, 06:50 PM   #18 (permalink)
Member # 2931
well i just got a complete 83 front end for repair parts and spare inner axles. $175. SCMK(john) where did you get those hella lights and how much? im gonna get 4. 2 for low beam and all 4 on for high beam... i got a set of little rectangle LED lights for blinkers--- i doubt ill make drews run ive got a rod knocking bad in the motor and some exo cage tubing that needs "adjustments".
color="lime">
Old 05-31-2002, 06:54 PM   #19 (permalink)
Member # 2931
Cliff
cliffy, call me (209)847-5172 or post, lemme know about motor options(ive got a new set of beadlocks for trade??)) how do you make a street legal buggy in calif???
color="lime">
Old 05-31-2002, 07:36 PM   #20 (permalink)
Wicked Raciest !
OOP'S's Avatar
Member # 30
I have thought about building a tube front end something like the Jeep guys do when the remove their front fenders!!
Old 05-31-2002, 08:04 PM   #21 (permalink)
Member # 2931
i like todds ideas, he inspired the flatbed
color="lime">
Old 05-31-2002, 09:00 PM   #22 (permalink)
Member # 2405
Im guessin about just over a hundo. I could prolly set a deal for about a hundo even. You interested? Ill set it up. Me got buddies in 4wpw. Sometimes. They can be on the rag at the time and gimme the redwings, so you never know.
I paid full price, so I got the redwings. But they only bleed for 7 days or less right?????? caulk me 422 6942
Old 05-31-2002, 10:01 PM   #23 (permalink)
Member # 2931
$100 for 4??? sweet! ill call you tomorrow night, i gotta work til 6pm, then go to folsom to pickup an 83 front axle to repair this weekends blunder
color="lime">
Old 05-31-2002, 10:13 PM   #24 (permalink)
Member # 2405
175 for a front end!!
Dude! I feel cheap and abused.
I guess I "used" to be a cheap whore till tonight!!
Thats too much Paul. Way too much. What are you gonna use? Just the hubs and inners??? Shit you dont want the housing. Its an 83!
What am I talkin about. I never broke any toy front, except a couple a tie rods. I guess Im a puss.
I have takin apart countless axles, for parts. never to fix my own!! I need more throttle power! My weber, header and *edit cam(i said carb @first) just dont cut it no mo. Triples dont mean shit. I just need a remote control i guess.
pinche joto!
Old 06-01-2002, 09:52 PM   #25 (permalink)
Member # 2931
i got it tonight minus the short side for $150. beer time, later
color="lime">
