Member # 80590
need pics of 1st gen yotas with front anti wrap bar
trying to figure out where in the hell im gonna mount my upper bar bracket to the frame. i gotta 4.3 v6 and the exhaust off the header runs directly parallel with the frame rail on both sides
Member # 55962
Take some pics of underneath and post 'em. Then we can get a better idea of what you're dealing with and come up with some ideas.
Everytime I see a hole I need to put something in it. |
Member # 80590
my springs sit completly flat at ride height. is a flatter spring gonna wrap up easier than a more u shaped spring does?
im thinking about adding a leaf to my pack and doing the bigger spring axle perches like these http://www.rubiconexpress.com/Produc...=D203B21719830 ill get pics tonight, ill be home @ 5 Last edited by intheworks; 05-30-2007 at 11:45 AM. |
Member # 55962
uh...yes. Flatter springs do have a tendency to wrap more because there is no arch to combat the wrap, but flatter springs do flex nice. You could try an old school trick and use a kicker shock from the front crossmember to the top of the axle. It doesn't completely prevent axle wrap, but it does help. And if you measure it roght it won't interfere with flex. Then there's the slip & twist and the shackle setup. Some people will tell you to run the shackle hanging down, other will say run it up. I have no personnel experience with the shackle setup. I use a slip & twist in the rear and the kicker shock in the front. No complaints yet cause wheel hop is almost nill and nothing has broke yet.
#10 (permalink) | |
Member # 80590
#13 (permalink) |
I woudl dig around the general section for snail wrap
http://www.jpmagazine.com/howto/16719/ EDIT: also make sure you use spring clamps
josh [URL=http://www.simbur.com/toyota4runner.htm]4runner[/URL] Last edited by greasyjeep; 05-30-2007 at 12:41 PM. |
#14 (permalink) |
Member # 4716
Anti-wrap leaf:
![]() A half-leaf on top of the springs with the front clamped under the other leaves. How-to: http://www.4crawler.com/4x4/4R_suspe...l#Update-part2 |
