I have a '92 toyota 4wd, 3.0 v6, p/u with auto hubs. When the 4wd is engaged the front drive shaft turns and the truck feels like its in 4wd but when trying to climb anything the front end seems to slip when under load. Also a distinct rattelling noise can be heard coming from the trans/ transfer case. Could something be slipping in the transfer case? Anyone had a similar problem? Please educate me on the subject. Thanks
The trans is 5 speed manual. I'm not a big fan of the hubs but unsure if the problem is there. The mystery noise seems to come from the transfer case, also when climbing the truck acts as if it is in low range but only 2wd. I,ve owned a 22re with manual hubs and never had a problem like this. ????
my '92 was vacuum engaged at the diff, hence the auto hubs. That seems like it's common to go out....just a thought. Put the truck on stands, put it in 4x4, and set it in drive in 1st 4lo. Then look at underneath - if the dshaft is turning and tires arent, problem is in the third/hubs. If driveshaft not turning, problem is in the case. If tires are turning and dshaft isn't, something really fucking weird is happening. Torch the shit and get insurance for it...and get a honda or something
Realize along with the auto hubs you have a chain drive transfer case. It may also be the chain is getting a bit worn. The ADD system for the front diff is vacuum operated as someone else mentioned. Check the vacuum lines for leaks.
