Ah sorry, I should have said -- I'm running E85 in my stock 22RE and want to optimize it for alcohol. E85 is 105 octane, 100% ethanol is around 125, both work best at 13:1.
If I can't get that much, what's the max?
I just laugh because trying to get a bump of 4 compression points via milling is rather insane.
For example, on my Acura motor, you can safely cut about 0.030 off it, that bumps you about 0.7 comp.
You'd end up taking around an 1/8th of an inch to get compression like that.
If you are too dumb to understand that, you are too dumb to build an engine that runs at 13:1 comp. There are questions in life that if you have to ask, the answer is no.
Hrey guys . I just changed my head gasket , timing chain steel guides , had the head machined , actually rebuilt . I set the timing at 5 degrees ( 22re) & its the timing feels retarded . I need to bump it up to about 12 degrees & it runs ok . I just want to be able to drive it .
I am wondering if they machined too much of the head ?
So the only way to do it is with pistons? I see LC has 12:1 pistons for $588 or custom for $649. That's pretty expensive --- maybe I should look for a junkyard turbo setup.
What are the problems with milling the head more -- does it weaken the head? Or is it just the problem with the cam gear and timing chain slack? That seems pretty easy to deal with.
I thought the 22RE pistons were flat topped. That's one of the major differences between the 20R and the 22R, right? The 20R has domed pistons and a combustion chamber of hmm, 85? 88? cc, and the 22R has flat pistons and a 58cc combustion chamber? But the LC 12:1 and 12.5:1 pistons for the 22RE are clearly domed in the pictures, to give the higher CR. And that would then change the non-interference nature of the engine too, it would seem.
