swapped a used 22re and 5spd into my toy, started fine for a month, then i let it sit and it wouldnt crank, got a new battery and checked al connections, still nothing, finally just hooked up a push button start from the battery to the starter, started up and worked fine for a few days, parked it and the next morniing it would just crank but wouldnt start, i got spark, jumpered the plug on the driverside to see if i get a hiss from the fuel rail, but nothing, got a new fuel filter but it didnt help, where would be a good spot to start to diagnose the fuel problem? new pump? kinda stuck just need a push in the right directions, any help would be good thanks
