i am installing a lock right in a 4cly diff and i am not sure what way the small spacer goes. one side has a thick ring and the other is thin. not sure how is the best way to explain it but one side is about 1/8in thick and the other side is about 1/4" thick. right now i have the thicker side against the diff pin instead of the splines.
That is not pertinent to what he's asking. The T-washers go on the outside of the couplers (spline side) and the spacers mount againt the inside (teeth side).
I know this was two days ago, and you probably figured it out, but I'm just trying to help...
This first picture kinda shows it, but put the "flat" side away from the coupler so the "skinnny" side's lip seats into the groove on the coupler or you'll never fit the pinion shaft between the drivers when you put it together
In the last week, i too just installed a lockright into a 4cyl diff and the thin side should be out towards the axle shafts and the side with the smaller diameter hole faces toward the pinion shaft. It states specifically in the instructions. It will only work this way with the thicker sides in towards the pinion shaft. If you look at the coupler that you slide into the carrier openings, there is a raised ridge that the large hole sits over. If not installed this way, the pinion shaft will not be able to go in... it should slide easily in(pinion shaft). installing them the other way will result in each spacer sitting off the coupler further resulting in a too small of a hole for the shaft to slide in.
sounds as though you installed them correctly. the larger hole should go outward towards axle shafts because they lip over the raised edge of the couplers. installing them the wrong way will not allow you to slip the shaft back in.
