Just got everything put together after upgrading to the Engine builder 268 cam. Was wondering how you guys trucks idle with this cam. Ive got the timing dead on and the carb adjusted pretty dang good and it does have a pretty good lope to it. I guess you could call it lope, or just a little bit of a rough idle. Also during normal driving there seems to be more vibration/rumble coming from the engine. I do have quite an exhast leak so that may have something to do with it.
But anyway, just looking for some opinions of the guys who run this cam. Thanks alot.
Mine is smooth as glass above 1200 RPM. A light lope to it at Idle. My motor has been balanced and port matched with the injectors all flow tested.
Sounds like you have other issues.
If the motor is fresh then get a couple hundred miles on it. Mine was pretty tight and it was noticeable right after it was built. After about 300 miles it loosened up. With 4K on it I'm loving it.
After correcting all other timing issues, plugging all loose vacuum, doing the regular tune up... add a multi-spark ignition like a Mallory 6AL. it makes the 22R purrr.
My R with a weber and the 268 kinda lopes and the idle is a little viby, but above 1100-1200 it's silky.
