I did my rears up front and I was wondering if I need the 12" or 14" shock hoops? I getting Trail Gears but I dont want to cut a hole in my inner finders if I dont need to!
Really depends on what length shocks and how much compression you want to have. Remember springs do not like to go negative very long. Bump stops are your friend unless someone sponsors your rig, and then let them go negative!!!!!
Nope no shocks no body lift. Im getting ready to order the right now. All I need to know is if RUF will give me 14" of travel if not then I will get the 12"
What year is your truck? 86 and up need the taller ones as the frame does not curve up as much as much as the 85 and below. You also need to look into shock length as stated above.
I preferred the 12's when i had my rears cause i had so much down travel that i didn't want my shocks to be limiing what i had.
