So I need new bushings for my springs. I've done the rears up front swap and have a few questions:
1. Do I get a rear spring bushing kit or a front spring bushing kit?
2. When I installed Sky's boomerang shackles the rear bushings (frame and spring) had to be clearanced to accomodate the thicker bolt. I would like to avoid doing this with brand new bushings. I'm not home to measure the bolt size and hole sizes and would like to place an order tonight online for the correct bushings, so...
What size would be the appropriate bushing given the bolt size is bigger than stock? Does anyone know what size or can recommend a kit that has worked without having to clearance anything?
Does anyone know what diameter the sky bolts are?
If I have to clearance the bushings is it possible to just use a smaller diameter bolt and shim his boomerang shackles to accept a smaller bolt-if so anyone know a shim source?
Thanks.
Thanks.
