ok,...how much throw am i suposed to have?....ive tryed 2 differant ones,...im only getting about 1/2 inch of throw....
i cant figure it out....for some reason i have to adjust the rod all the way out,..basicly resting the release bearing on the presure plate...when both transfers are in high range the clutch slips at full throttle....but when the front case is in low,..it dosent slip....
i just replaced the clutch yesterday...ive got a 95 22re 2wd motor with a 1980 4-speed....i had to buy a 95 2wd clutch kit with a 1980 throw out bearing....my release arm needs to move about 2-3 inches for the clutch to work properly....and yes ive bled the system very well a few times....
any ideas???
do i need a custom settup?...or have i gotton a few bad slave cycl's?....i dont have a stock one to look at
any ideas???
