Found this inside the drivers kick panel of my 85 Xtra Cab 22R. Had a couple wires hooked into my brake light wiring, other than that everything plugged into it was just stuffed in there except for one plug that ran up into the engine compartment and went nowhere. What the hell is it though? Pulled it and it's associated wiring out and it didn't effect anything, truck still starts up lights work (well, as much as they did).
The label says "OEM Replica Series Manual Transmission Electronics Module" There's a power light, engage light. Centering and System Sensitivity adjustment, and a dial to select 4, 6 or 8 cylinders. P/N 2700141
