Well I took the buggy out, this weekend, for the first time this summer. All was well till along set of hill climbs one after another. I heard a pisssss..
Looked back and the over flow bottle was pissing fluid.
I run a 22R on Propane, The Radiator(From a V6) is mounted behind the two seats, will a small tranny cooler, in front of the radiator.
I have been running a Tauras Electric Fan, the winter months I had it blowing forward for heat, well I switched, to pull instead of push, due to summer time.
At first I thought I had to much gear around it, wasnt getting enough air... So relocated it, and worked fine, then noticed it creeping up again...
The Buggy got up to 240, the other times it would get to 220, and I would shut it down, let it cool to 180-190.
I am running the stock water pump. So I am wondering is this suffecient? The water is plumbed under buggy, thru Muffler pipe, then into regular radiator hoses. I did notice maybe, the exhaust running next to return line, may need some heat wrap.
Are most guys running dual fans?... I could have one Push, and one Pull. Upgrade to a faster fan? Upgrade water pump?
Thoughts?
Thoughts?
