I put fuel injection on my toyota, everything seems right but, right when you roll of on the throttle it has a hesitation/sputter, and then the throttle picks up.
After it warms up a little it seems not to do it as bad......got any ideas on what it could be? Also the check engine light, comes on somtimes ,but then goes right back off.
I've cleaned injectors, changed the mass air flow, checked the TPS, all with no luck???
