Driveshaft breakage problems - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-21-2007, 06:53 PM   #1 (permalink)
Member # 37913
Send a message via AIM to lostcreek18
So I've broken a few toyota driveshaft u-joints lately and I'm looking for a couple ways to upgrade.
Here's my set-up:
91 toyota pickup, chevy tbi 350 engine with th350 tranny mated to toyota dual cases with 4.7's in the rear case. I'm running a front driveshaft that's been lengthened and stock toyota u-joints. For the front I have a stock toyota front CV welded to square.
I broke a rear driveshaft joint a month ago and blew out a cap on my front joint at the same time. Just today I put a new cap in my front cv because I threw another cap after the snap ring flew off a few days ago so I replaced the snap rings with full circles snap rings. Today the joint broke in half. It always seems to be the u-joint at the axle end of the CV(if that makes any sense) I'm wondering if running a single joint on both ends of my front shaft would be better than the cv in there? The truck doesn't see any street time so vibrations are not a big deal. Anyone have any input on this?
91 toyota, 35 spline 60's front and rear, tbi 350, th350, np231 with 300 behind it, waggys up front, 4 link and air shocks out back, 42 Iroks and some more stuff, I forget
95 Dodge 2500 cummins
lostcreek18 is offline   Reply With Quote
Old 07-21-2007, 07:19 PM   #2 (permalink)
Member # 27879
I have broken quite a few toyota joints, (4.3l, 40's) and i have found that welding the cap in helps alot. If your drivelines are at a severe angle and axlewrap or the suspension dropping out makes the angle worse, try making your pinion angle a less severe and adding a limit strap. That helped my rear out alot. There is also a new Trail Gear U-joint that has a beefier center for $40 that I want to try.
83' Toy, tubed, swapped, crawlered and chromoed
Turtle Bite is offline   Reply With Quote
Old 07-21-2007, 09:25 PM   #3 (permalink)
Member # 37913
Ya I put those full circle snap rings on so I don't throw caps anymore but I did think about welding them.
As for the pinion angle I'm running a high pinion so my angle is almost nothing. The shafts don't bind at all at full droop or anything. I looked into the heavy duty creeper joints that trail gear has but I wanted to try the single joint front driveshaft idea first
Old 07-21-2007, 09:27 PM   #4 (permalink)
metchosin joe's Avatar
Member # 37213
got much axle wrap? traction bar would take some stress away
Toyota with Stickies, links, beverage holder and other accessories
metchosin joe is offline   Reply With Quote
Old 07-22-2007, 09:04 AM   #5 (permalink)
Member # 16789
Where are you finding the full circle snap rings for the Yota U-Joints and CV's?
The Parts Pimp.
Wanted! Solid axle steering boxes from 1979-1985 toyota pick-ups and four runners. PM me for details.
Wanted! Power assist Rams and Valves from 75-77 Ford F-250's. PM me for details.
$78 for Toyota front knuckle rebuild kits DELIVERED!! PM me for details.
montezuma is online now   Reply With Quote
Old 07-22-2007, 09:51 AM   #6 (permalink)
Member # 37913
My front isn't getting any axle wrap so I don't think that is a problem.
I just went to a hardware store and took a joint with me and found some full circle snap rings. I'm pretty sure they are the 1" ones.
Old 07-23-2007, 10:12 AM   #7 (permalink)
Member # 80590
i got toyota driveshafts front and rear with a big ol bitch 4runner and dana 60's
since i put creeper joints f+r from tral-gear i can break axle shafts before the driveshafts give.
intheworks is offline   Reply With Quote
Old 07-23-2007, 10:13 AM   #8 (permalink)
Member # 80590
thats what i do too! tack weld the caps
Old 07-24-2007, 05:47 PM   #9 (permalink)
Member # 37913
Are you running chromo shafts up front?
