'97 4runner won't start - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-29-2007, 08:27 PM   #1 (permalink)
TxCruzr's Avatar
Member # 9380
Send a message via AIM to TxCruzr
I'm going to go work on my brothers 4runner this weekend and want to get some ideas on what to look at.
It is a '97 4runner with v6 and was running fine until the starter solenoid freaked out and kept turning the starter when the motor was already started and running. Since it has over 200k miles he went ahead and replaced the whole starter and solenoid but now it will just crank. So either no fuel or no spark.
Since it was running fine right before this my first thought is maybe a fuse blew when the starter went ape shit.
Second, I don't know if 4runners have it or not, but when he put the battery terminal back on the anti-theft alarm went off and it took him a while to turn it off since he didn't have the key with the button on it. I was thinking maybe there is some anti-theft switch of some type that shuts the fuel pump off like in fords when they are in a accident and it just needs to be reset.
Other then that I cannot imagine the fuel pump crapping out a split second after the starter did.
Also thinking maybe the ignition switch took a dive with the starter?
Any ideas on what to look for or if a '97 4runner has any type of fuel pump shut off switch or relay? Google hasn't been very helpful so far.
Thanks!
TxCruzr is offline   Reply With Quote Quick reply to this message
Old 10-29-2007, 08:37 PM   #2 (permalink)
Member # 16719
did he disconnect the battery before diving in?
jdrocks is offline   Reply With Quote Quick reply to this message
Old 10-29-2007, 08:50 PM   #3 (permalink)
TxCruzr's Avatar
Member # 9380
He had the battery disconnected when he replaced the starter. Also wondering if the computer has some anti-theft deal and just needs to have the battery disconnected for a while to reset it and then when reconnected, be ready to shut the alarm off with the key.
Old 10-29-2007, 10:38 PM   #4 (permalink)
Member # 73413
check fusible links
Bansheestu is offline   Reply With Quote Quick reply to this message
Old 10-29-2007, 11:25 PM   #5 (permalink)
Member # 86771
They have the fuse for the ignitor its a square one that you have to buy special at autozone they run about 5 dollars. I had the same problem one day it turned out I just knocked off the wire that goes to the ignitor and was not making contact. good luck
tomjordanphoto is offline   Reply With Quote Quick reply to this message
Old 10-30-2007, 12:01 AM   #6 (permalink)
Member # 88698
Disconnect the battery, then put the key in and turn it to the on position, then reconnect the battery....sometimes, depending on what antitheft system is in the car, this will get past it. Give it a shot.
LBHSBZ is offline   Reply With Quote Quick reply to this message
Old 10-30-2007, 12:03 AM   #7 (permalink)
Member # 88600
check the EFI fuse, i had one and that blew a few times
83sleepr is offline   Reply With Quote Quick reply to this message
Old 10-30-2007, 12:13 AM   #8 (permalink)
TxCruzr's Avatar
Member # 9380
Where are these fuses at, both the efi and the igniter fuse? I haven't see the car in a few years but I want to say there is a fuse box by the dash and also one under the hood.
Stupid technology, if this was my cruiser I would only have to check 12 fuses and 3 or 4 wires
Old 10-30-2007, 09:28 AM   #9 (permalink)
Grocery Getter
ErikB's Avatar
Member # 59
No, not from the factory anyway.
