Elocker up front. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-10-2007, 06:37 AM   #1 (permalink)
White Trash Fab
smewhtguy's Avatar
Member # 100827
Send a message via AIM to smewhtguy
Question Elocker up front.
Stupid question did search and read the faq can you put 00 elocker in an 85 mini front sa. I read the article on how to install it in a rear axle and am just wondering if the same is true to putting it in a front axle.
"If you are gonna live life on the edge you better have good balance"
06 Tundra DC
The "Trifecta" 3 seat yota buggy
http://pirate4x4.com/forum/showthread.php?t=1027210
http://www.AddictedOffroad.com/
www.ruffstuffspecialties.com
http://f-o-a.com
smewhtguy is offline   Reply With Quote
Old 12-10-2007, 06:43 AM   #2 (permalink)
Marc P's Avatar
Member # 27945
I am in the process right now....yes it is possible.
I followed this writeup
http://67.122.16.97/carterman/4runner/mods/locker/
95 Runner--axle swapped, double locked, and armored...GONE
1998 4runner...under construction
Marc P is offline   Reply With Quote
Old 12-10-2007, 10:55 AM   #3 (permalink)
Banned
Member # 81707
Send a message via AIM to cliffstoyota
You will have to grind the third member houseing to clear the ubolts
cliffstoyota is offline   Reply With Quote
Old 12-10-2007, 11:19 AM   #4 (permalink)
Marc P's Avatar
Member # 27945
I was able to file just a little on the housing. The u-bolt barely fits, but it does.
Old 12-10-2007, 09:48 PM   #5 (permalink)
Member # 80948
e-locker
yes, it can be done. I have even installed the e-lockers in Samurai's where clearance is even closer. For clearance with the leaf spring on the passenger side, there is one 10mm bolt on the shift fork cap that some people choose to go to a countersunk bolt, however there are many running the setup with the top bolt just left out with no problems. Some have to trim the motor slightly where the e-locker connector bracket mounts to, but this is ok also because the harness is still supported by the stud and nut going through to the axle housing. If you need any help with your installation, let me know. We also stock electric locking differential conversion parts to make your installation easier.
Low Range is offline   Reply With Quote
Old 12-11-2007, 08:43 AM   #6 (permalink)
Member # 711
Do you have any tips for drilling the holes in the housing so that they are perpendicular and centered relative to the holes in the carrier? I am thinking about sourcing some dowels that I could drop in the carrier mounting holes so that the drill bit has something to align to as I drill the holes.
Also, is it necessary to weld the area where the grind breaks through the existing hole in the carrier withinin the narrow area of the gasket?
76tlc is offline   Reply With Quote
Old 12-11-2007, 09:05 AM   #7 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Start the hole with a 10mm bit so it sits dead center in the carrier hole. As soon as the drill starts to cut, drop back to the appropriately sized drill for your tap.
I've used this technique to align holes in my t-case xmember (with the #4 t-case plate as a guide) and also to use a factory D44 diff cover to place holes on a 3/8" ring when building a thicker diff cover.
It can't hurt.
Anyone have any good pictures of handmade e-locker motor guards?
Here's Lowrange's $23.75 (high pinion):
Lowrange, do you have a low pinion model?
Inchworm's $75:
http://www.inchwormgear.com/store/pr...products_id=58
Sky's $39:
http://www.sky-manufacturing.com/
FROR $75:
4x4wire's e-locker writeup--with schematics:
http://www.4x4wire.com/toyota/tech/electric_locker/
MT4Runner is offline   Reply With Quote
Old 12-11-2007, 09:10 AM   #8 (permalink)
Marc P's Avatar
Member # 27945
I had no trouble drilling the holes with a cheap B&D drill. I bolted the 3rd to the housing and drilled pilot holes.
I ordered Sky's e-locker skid.
Old 12-11-2007, 10:12 AM   #9 (permalink)
Member # 78856
When I did my rear elocker I didn't add any material to the sealing surface. I used a factory elocker gasket. So far I haven't had any leaks.
85 4runner
97 4runner
MtnToys is offline   Reply With Quote
Old 03-18-2010, 08:45 PM   #10 (permalink)
TatonkaII's Avatar
Member # 12454
Send a message via AIM to TatonkaII
T T T, does anyone have the write up to this anymore? Seems straight forward really.. but I tend to over think things.
85 3.4 V6, 38s, Longs, 4.7 Marlins, 5" AP springs.. almost done..www.chucktownlowdown.com
TatonkaII is offline   Reply With Quote
Old 03-18-2010, 08:48 PM   #11 (permalink)
Hottrod81's Avatar
Member # 36464
Don't overthink it. There isn't anything more to add. It's staightforward like the write up above.
Hottrod81 is offline   Reply With Quote
Old 03-18-2010, 08:52 PM   #12 (permalink)
chrissybf86's Avatar
Member # 68634
yea i have a e-locker in my 83 front. same as doing it in the rear but u might have to do some clearence work on the passenger side leafs or u bolts.
Adrenaline motorsports 08 evox 500+awhp 2.3 fp-red fully built clean sas runner build
chrissybf86 is offline   Reply With Quote
Old 04-10-2010, 11:22 AM   #13 (permalink)
Member # 128249
If you use the electric locking differential gasket (Toyota part 42181-60050) as a template to identify where to grind, drill and tap ***MAKE SURE you dont have the gasket UPSIDE DOWN***. I did this and the two 4" stud holes dont line up
g-man runner is offline   Reply With Quote
Old 04-10-2010, 03:27 PM   #14 (permalink)
DuCaTi MoNsTeR
Booger Weldz's Avatar
Member # 2931
12voltguys Elocker wiring harness/switch is fukin awesome for this!
Elockers suck up front IMO for technical rockcrawlingas they are slow to engage often requiring you to drive for quite a few feet before it engages...ive only run the stock TRD rear setup on my truck when it wasnt a crawler on slippery boat ramps and it took like 10 feet sometimes before it was engaged
Amongst the best of the toyota vendors:
Www.4wheelunderground.com
Www.addictedoffroad.com
Www.hellfire-fabworks.com
Booger Weldz is online now   Reply With Quote
Old 04-10-2010, 03:36 PM   #15 (permalink)
Member # 140945
seems like my front e-locker engages way faster than my rear e-locker especially with the wheels turned.
-Jake- is offline   Reply With Quote
Old 04-10-2010, 03:41 PM   #16 (permalink)
DuCaTi MoNsTeR
Member # 2931
maybe steering helps unbind it so it can engage quicker since the wheels travel at diff speeds?
Old 04-10-2010, 03:44 PM   #17 (permalink)
Member # 140945
thats what I think
Old 04-10-2010, 11:04 PM   #18 (permalink)
Member # 15993
My front will engage just by turning the steering wheel back and forth once about 45* even with the vehicle sitting still. Never had one in a rear axle to compare though.
molsenmuscle is offline   Reply With Quote
Old 04-11-2010, 07:09 AM   #19 (permalink)
Lets Ride
ricsrx's Avatar
Member # 131553
I need to try that, some times it will go right in some times not
ricsrx is offline   Reply With Quote
