Member # 71337
Mercedes Turbo-Diesel to W56- UPDATE PG -8
I'm not sure if you folks will be interested in this engine swap/build. So, I'll leave it up to you. We have NO rock-crawling near my Maryland home, and almost no offroad trails in the area. This truck is going to become my daily driver/ work truck/ farm truck.
The truck is ready for paint. I spared you guys the chassis/body mods since it's pretty mundane compared to the crazy shit you folks build. I wanted a old 4-door Hi-Lux, but since the U.S. never got that, I made a four-seater with a short bed. Sorry for the crappy first pic.
No one here is gunna caress your nut sack. We tell it how it is.:flipoff2: Last edited by Roy's Rustbucket; 04-26-2009 at 05:08 PM. Reason: Update |
Member # 71495
more pics please
[URL="http://yotamasters.com/"]http://yotamasters.com/[/URL] :flipoff2:The only jeep in my family is pink and my 4 year old drives it:flipoff2: |
Member # 71337
(begin shameless suck-up)
The reason I wanted to post this thread HERE, is because of the tremendous fabrication and machinist skills I've seen on Pirate. I hope you folks can see past my non-rockcrawler limitations. (end suck-up)On to the swap....... ![]() Mating the W56 to the Benz engine looks like it's going to be a little involved. (This is my first engine swap by the way) I know this can be done because I have some limited photos from a guy who did it. He was a machinist, and he couldn't remember all the details of what parts he used, and the photos show little detail. These were second-hand pics and info. I found the thread on ToyotaDieselMadness.com of someone who planned to replicate the swap, but later, he decided to keep the Benz auto-trans and leave the truck 2WD.
No one here is gunna caress your nut sack. We tell it how it is.:flipoff2: Last edited by Roy's Rustbucket; 01-06-2008 at 05:33 PM. |
#5 (permalink) | |
Member # 71337
I am wide-open to input on any of this. Roy
No one here is gunna caress your nut sack. We tell it how it is.:flipoff2: Last edited by Roy's Rustbucket; 01-06-2008 at 05:47 PM. |
Member # 71337
Removed the transmission today, and mainly sat and familiarized myself with the engine layout, plumbing, etc.
This is an all-mechanical diesel. No electronics of any kind. This engine in stock form, is rated at 125HP and 175 lbs of torque. I've been reading up on the Benz forums, and with a few simple mods, can produce about 170HP and 240 lbs. of torque. Intercooling this engine is pretty straight forward as well. The "OM" series engines are known as the most dependable engines Mercedes has ever produced; many going 400,000+ miles before needing a rebuild.
No one here is gunna caress your nut sack. We tell it how it is.:flipoff2: Last edited by Roy's Rustbucket; 01-06-2008 at 05:48 PM. |
Member # 30371
Please keep us posted with pictures!
I have looked at the merc diesels for a swap MANY times, but I don't have the equipment to adapt the transmission. I can't wait to see what you come up with. |
Member # 12329
Ooh, I'll be watching. I've often thought this would be a great swap. I think it was 4x4labs that was working on a kit.
ETA: I'd be very interested to see the pics you have of a successful swap.
The force that through the green fuse drives the flower drives my green age That blasts the root of trees is my destroyer And I am dumb to tell the crooked rose My youth is bent by the same wintry fever Last edited by dreamerof1; 01-06-2008 at 09:00 PM. |
Ever thought of dumping your benz diesel for an audi one? Audi Diesels had an asian warner auto trans behind them, which is the same auto trans that came in 22re/auto toyota trucks. This means you can use an inchworm adapter to a gear drive transfer case. They motor can be easily found in late 80's Volvo sedans.
Member # 71337
Here is the thread that has the pics of the first install with the five-speed.
I don't want to link to all the pics because it might be a Pirate bandwidth issue. Roy http://toyotadiesel.com/forums/showt...light=mercedes
No one here is gunna caress your nut sack. We tell it how it is.:flipoff2: |
#12 (permalink) | |
Member # 71337
Well, since I already have this, I'm going to use it. I looked at Volvo and Isuzu diesels as well as turbocharging a 240D Benz. This is just what I found nearby at a reasonable price. Roy
#13 (permalink) |
Member # 39959
Please Please Please dont give up! I wanna see this happen. 4x4labs was (is?) working on a kit that I've been drooling over for some time. Their website has been all jacked for a long time so its hard to find the info. I've called them a few times and was put on their list of people to get ahold of when its done but that was a loooong time ago. But you might try to give them call.
#14 (permalink) |
Member # 19373
sounds like a interesting project, I will be keeping an eye on the build. I too want to see how you adapt the motor to tranny.
[CENTER]When the power of love overcomes the love of power, the world will know peace. -Jimi Hendrix[/CENTER] [QUOTE=steveh;7244017]Keep it on track guys. DRM and I will be watching. We need our TG paychecks ...... [/QUOTE] |
#15 (permalink) |
Member # 71337
Very few 300TD's came to the U.S. with manual transmissions. I believe they use a 33lb flywheel. The 240D uses a 23lb flywheel.
Both are a bolt-on swap.
#16 (permalink) |
why not use a 300td manual flywheel with the 240d tranny? cuz u cant get a hold of one?
I wanted to do this. it will be interesting to find out your results. good luck!
'79 Toyota Hilux DD - Project NutKase http://pirate4x4.com/forum/showthread.php?p=9337997 '87 2wd Toyota Pickup, 32/36 on the back burner |
#17 (permalink) |
I'm watching this one also.. If only the transmission issue was easier.. :-)
My first car was a 220d. Even weaker than the 240D. I heard it made it over 300k, eventually dropped the timing chain.
[url=http://22returbo.com]22returbo.net[/url] [url=http://lakebox.dnsalias.com/photos/1981%20toyota/megasquirt/]1981 Toyota 22r Supercharged (fuel only) - sold [/url] [url=http://22returbo.com]1988 22RE turbo 4Runner[/url] |
#18 (permalink) |
Member # 69745
mmm, inline 5 cylinder diesel - i drove a '79 300sd turbo diesel for a few years - never gave me a single problem. engine's definitely better suited to a truck than a sedan, it was slow as molasses.
#19 (permalink) |
Member # 30266
Have you tried putting the engine in the engine bay? I tried it with mine and had to go a different route....that is a long sucka!
and just so you know - Rausch Creek probably is less than 2 hours for you for wheeling and has some fantastic wheeling... bk
"I'm a horny engineer. I never joke about math or sex." - Walowitz - The Big Bang Theory. Last edited by bkfj55; 01-08-2008 at 03:04 AM. |
#20 (permalink) |
I had exchanged e-mails with 4x4Labs about their conversion project a few years ago. IIRC, the fact that the engine and transmission were balanced together was the issue that was stopping them. Will be interested to see how this progresses.
GET INVOLVED - Join the Blue Ribbon Coalition SIGN THE PETITION - SAVETHEHAMMERS - #85 '93 Chevrolet 6.5TD K2500 NV4500 Std. Cab Longbed 170K '85 Toyota 22R RN60 4x4 Std. Cab Shortbed 178K (Currently retired for rebuild) |
#21 (permalink) | |
Member # 71337
Finding a 300TD manual flywheel will be tough. It's my understanding that very few manual 300TD's came to the U.S. This path gives the option of using a Toyota transfer case doubler. I'm also hoping for better mileage with the five speed. If I used the Benz trans, I would still need a divorced transfer case set-up since the Toyota trans and transfer case are integral.
No one here is gunna caress your nut sack. We tell it how it is.:flipoff2: Last edited by Roy's Rustbucket; 01-08-2008 at 05:49 PM. |
#22 (permalink) | |
Member # 71337
I have had the engine in the bay, and I think I have the length issue solved as well. We'll see.
#23 (permalink) | |
Member # 71337
Tonight, I pulled the flex-plate and the Benz transmission "transition" plate that goes between the trans and engine block. I threw those in the trunk along with the Toyota manual flywheel. I'm now waiting on delivery of the 240D manual-flywheel I got on eBay. Progress will slow until that arrives. While I'm waiting, I think I'm probably going to organize the garage and strip the engine down to the long block, clean and paint everything. A wire was between the valve cover and head, and everything is pretty damn filthy. I'll post updates as they occur. Roy
#24 (permalink) |
Question on the bodywork - did you extend the cab of a pickup into the bed or is that a 4-Runner you are starting with? The Merc engine is cool as well, but I always like a purpose built rig whatever the configuration.
#25 (permalink) | |
Member # 71337
Roy
