22RE egr problem - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-26-2008, 09:24 AM   #1 (permalink)
Member # 93453
22RE egr problem
Hi all, hoping someone can help me figure out my egr problem? My '85 4Runner failed the CA smog test (NOX) and all symptoms point to the egr system. I've checked the egr valve with a vacuum pump (nothing happened) and even tried swapping it from another 22RE. It seems like nothing is coming out of the egr port on the head? I'm pretty sure the port on the intake manifold is clear because as soon as I unhook the pipe from it it kills the engine? Any help is greatly appreciated!
1985 4Runner x2
1993 xtra-cab Hilux
elbutcho is offline   Reply With Quote Quick reply to this message
Old 05-26-2008, 10:37 AM   #2 (permalink)
Member # 106389
there is a EGR cooler located on the back of the head. over time they can become clogged.
of course your engine will stall when you open a huge hole in the vacuum
gus straussen is offline   Reply With Quote Quick reply to this message
Old 05-26-2008, 04:49 PM   #3 (permalink)
slabcrawler's Avatar
Member # 47541
Check and make sure the egr port in your plenum is clear. It runs all the way to the front of the manifold then makes a 90 degree turn. Pull the egr valve and blow air in there to see if it's clear. If it's plugged you have to pull the small freeze plug on the side of the manifold whre the passage makes the 90 degree turn to get all the carbon out. Also clean our or replace the egr modulator before your next test and put de natured alchohol in the tank.
slabcrawler is offline   Reply With Quote Quick reply to this message
Old 05-26-2008, 06:35 PM   #4 (permalink)
854X4's Avatar
Member # 31273
I didnt know that was a freeze plug. Does anyone know what size it is?
854X4 is offline   Reply With Quote Quick reply to this message
Old 05-26-2008, 10:22 PM   #5 (permalink)
Member # 111963
go get some freaken calipers find out for your self
Killam4x4 is offline   Reply With Quote Quick reply to this message
Old 05-26-2008, 10:34 PM   #6 (permalink)
Krusty's Avatar
Member # 906
find a different smog tech !!!!!
Krusty, aka. Krustoy
Official Tin Bender.
older than dirt/before rocks were invented!
*Cancer survivor since 02-06*
Grand Marshall -KOH 2012
"Dad' to some of the greatest kids EVER
I was around when Pearl Harbor was bombed !
Krusty is offline   Reply With Quote Quick reply to this message
