Anyone know normal Operating TEMP 22RE ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-20-2002, 02:52 PM   #1 (permalink)
Chopperman's Avatar
Member # 2634
I have a freind who is battling a temp problem, we have replaced everything we can think of including new rad, and new long block. It's not a serious overheating problem, but we can't seem to get a firm answer from anyone on normal operating temp. Anyone know ???
Chopperman is offline   Reply With Quote Quick reply to this message
Old 07-20-2002, 03:16 PM   #2 (permalink)
Member # 3583
Send a message via ICQ to Cracker
IIRC,
the 22R uses a 180* thermostat, and the 22RE uses a 190* (or 195*?) thermostat.........
I have heard of people running the 180* stat in the 22RE........
You might try that..........
[color=green][size=4]Art[/size][/color]
[color=yellow]99 Taco
80 Hilux - 20/22R Hybrid, Dual Mikuni's, R151 trans, Budbuilt X-member
[/color]
Vini Vidi Velcro
I came, I saw, I stuck around
Cracker is offline   Reply With Quote Quick reply to this message
Old 07-20-2002, 03:30 PM   #3 (permalink)
Member # 6529
190* to 220* is is fine. when you start hitting 230, its getting too hot. under 185 and the fuel injection stays in open loop and doesn't work properly. The temp rating of the thermostat is just the temp that it opens at. It mainly has to do with how quickly the engine warms up, and only factors in the minimum operating temp.
zags is offline   Reply With Quote Quick reply to this message
Old 07-20-2002, 08:38 PM   #4 (permalink)
Member # 26
I set my fan to start up at 200 degrees.
230 is about max on these motors. Too hot and they will toss a head gasket.
Chris Geiger is offline   Reply With Quote Quick reply to this message
Old 07-20-2002, 09:31 PM   #5 (permalink)
tALL bASTARD's Avatar
Member # 6682
Send a message via AIM to tALL bASTARD
Mine sits anywhere around 170-190 on my mech. water temp gauge that was installed in the factory sending location. I did replace the thermostat when I did my head gasket in Dec, but I dont remember the rating of it. This is with Az heat (110 degrees and the air on in city driving as well). Dunno, get a two stage thermostat from Toyota if you do replace it, the part number is prob under here if you search for it, or check Roger Browns site. Later
Enginerd
Impossible only takes longer.
'Fate is what you call it when you don't know the name of the person screwing you over.'
tALL bASTARD is offline   Reply With Quote Quick reply to this message
