Member # 120942
Cluster backlights not working anymore.
So I replaced the module that has the turn signal and wiper handles on it out of another rig the other day because my hazard light switch was facing the wrong direction for the steering column cover I had for it. Anyways, everything worked just fine after hooking up the harnesses and all that. I had to unplug them in order to route the wires correctly and mount them under the column where they go. I had accidentally left the headlights on when I plugged the harness back in and I heard a pop. Now my cluster backlights do not work. I did check to verify that the bulbs work, and my turn signals work, and all the other idiot lights, just not the backlights. I have checked every fuse in the kickpanel and under the hood. Anything else I can check for this?
Member # 120942
If i remembery correctly it was from under the dash drivers side where i was plugging in the plug on the bottom of the steering column but can't remember for 100%, don't think it came from cluster tho.
Pull the cluster and look very closely at the inbeded copper plastc circuits for one thats smoked..... They are thin and will act like a fuse if they happen to make contact with anything metal...
Why is it we all are for doing the same thing--but yet we can not work together to achieve it Mike Crash Kash The new live streaming video crashfab |
