#651 (permalink) |
Mooseknuckle OG
Member # 139159
Damn dude your luck with gears. Hope you can get everything figured out in time for the Naches trip!
Btw shoot me a txt with the dates if you have found them out. Gotta give the boss a little heads up and figure out what my deadline is.
"You break on the trail, You BECOME the trail!" - drunk guy MY BUILD http://www.pirate4x4.com/forum/showt...083&highlight= |
#652 (permalink) |
Member # 78
Fore the toyota purist looking for more R&P strength:
http://www.ih8mud.com/tech/hybrid.php You can also use IFS rear axles for a wider setup, still using the early mini axle tubes for proper fit in the cruiser center. |
#653 (permalink) |
Member # 203358
Ok cool, that clears up a giant portion of my problems, thanks alot guys.
one more question that i didnt seem to find, What cam are you guys running? theres a stock cam currently in the motor and i was given a new unused enginbldr 268 cam. what would be better? or should i look for a new cam? thanks again.
#654 (permalink) | |
Member # 209340
--- I am here: http://tapatalk.com/map.php?dqz4uy |
#655 (permalink) |
Member # 102813
My friends call me "The butcher" Because I didnt know until now how important this really is..... Outstanding businesses (going above and beyond) that I have dealt with to date: Marlin Crawler Hellfire Fabworks Daves Offroad gearinstalls.com (Zuk) Local 125 |
#657 (permalink) | |
Davez Off Road
Sorry for all the questions, just pounding out all the little things on my new turbo engine. My old one would detonate under full throttle, I coudnt get a dist in with the vac advance so I toook the whole thing a part and made the timing adjustable. Total advance at 29 deg worked the best but not a lot of boost. I plan on hitting the 12-15 mark with this one.
Great deals on Toyota Parts: : http://www.davezoffroadperformance.com/ Most Trail-Gear parts FREE shipping.Yukon parts on SALE 3rd Members priced right. 530-622-2148 for all your electrical needs http://www.12voltguy.com/ WIN a fully built Toy p/u http://www.pirate4x4.com/forum/toyot...toyota-pu.html |
#658 (permalink) |
bummer about those gears, but I seriously wish I knew you'd be out at schwartz. I'd love to see your runner in action.
The funny thing is that it seems I've ruined some diff gears at schwartz on saturday.
86 yota pickup:[url]http://www.pirate4x4.com/forum/showthread.php?t=632103[/url] |
#659 (permalink) |
Member # 102813
First thing first.... I need to tune the dizzy while listening for pre-det at WOT. I have never been good at knowing what to listen to and this rig is stupid loud right now. I am working on the exhaust to quiet it down and trying to find a good area to get her spooled up and legs stretched.
From my understanding, 12 is at the top end of a mech dizzys range. After that a stand alone system is in order.
#660 (permalink) | |
shoes optional
Member # 142117
reading this seems like something id hear in one of those rap songs, hey isnt there a machine shop in NorthP that could re-thread a jonny joint(1" to 7/8"), i went to the machine shop in my town ForestG and they said there was someone in NP that can do what i need. do you have any experience or knowledge of the shop im asking about |
#661 (permalink) |
Davez Off Road
The mechanical advance will hit 51 degrees at total advance. At only 5lbs I was having detonation problems until I gutted an older 22r distributor and made it adjustable for a total advance of 28 degrees. I was able to run WOT at that point with no issues, On 97 octane
#662 (permalink) | |
Piggin' Ain't Easy
Stubs is running propane also, which is ~110 octane, plus the draw through turbo doesn't lean out. Tech on modding distributor? Links?
Nick Cooper StockRunner build (stock height link suspension) turned firewall buggy Gremlin build - small ugly linked beater truck |
#663 (permalink) |
Member # 102813
Replaced my busted gear set with a welded 6 cyl third and a new Nitro Gear R&P from JT diff.
Also rebuilt the trac bar. Opened up the mount point at the axle, lengthened the shackle, and beefed up the tubes. 1.75 sleeved with 1.25 DOM on both the top and bottom tubes and a piece of 1.5 x 1.5 x .25 angle on the bottom. ![]() ![]()
#665 (permalink) |
Member # 102813
Took Krunch out this weekend on sat. Had a good time with a few friends.
No new breakage's. Here is a link to the PNW section /forum/usa-northwest/1068805-tsf-5-26-12-a.html We crawled the lower section of the Crushers before it began to rain. Then we hit up 7-Up. Only one of the three who tried was successful. I came close but I had vaginal issues with my leaf springs unloading while backing down. ![]() ![]() ![]() TSF Crushers - YouTube TSF Crushers - YouTube TSF 7-up - YouTube TSF 7-up - YouTube My son in a friends rig..... TSF Crushers - YouTube Pulled line on this one. It was on the teeter totter verge.... TAF Crushers - YouTube
#667 (permalink) | |
Member # 89727
No breakage is a good day
1981 Toyota Trekker 220:1 |
#669 (permalink) |
0[III]O
Member # 132064
Hey Stubs, this may be a fairly retarded question for and some other seasoned rock crawlers here but in your second video right about the 49 second mark your driver side tire was turning before passenger started. Your spooled up front right? If so, what was twisting before the tire started to turn?
BUY MY Toy/Lexus 3.0 clutch...http://www.pirate4x4.com/forum/showt...222&highlight= Bendix Tuflo compressor http://www.pirate4x4.com/forum/misc-...ompressor.html I NEED Cadillac 425 rear sump pan |
#670 (permalink) |
Member # 102813
So due to peer pressure I decided to paint Krunch...... Spent more money and time than I wanted to for something that wont last...
#671 (permalink) |
Member # 102813
I am not spooled in the front. It is a Grizzly locker. What you are seeing is the slop in the locker before it engages. It is pronounced due to how slow the tires are turning. The Detroit in the front of Ol' Blue is the same.
#672 (permalink) |
Member # 216615
your kid pulled a wheel stand like it was nothing ha that was pretty sweet to watch
![]() with new paint is it raspberry crunch or strawberry crunch now? Last edited by ToyoTanner; 05-30-2012 at 09:08 PM. |
#674 (permalink) |
Mooseknuckle OG
Member # 139159
Looks fucking badass man!
#675 (permalink) |
Member # 102813
Finished up my exhaust. Put a Moroso spiral flow race muffler, flex coupler and some heat wrap up buy the turbo.
Seems to have quieted it down a bit (thank god) but I havent done anything but rev it up in the shop. The longer pipe hopefully will keep the in cab temp down and the down turn keep more noise out of my ear.. ![]()
