Blueberry Krunch - Page 29 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-28-2012, 05:57 PM   #701 (permalink)
Mr Stubs's Avatar
Member # 102813
Originally Posted by meatmonkey View Post
Any concerns for either your crossmember bushings or T-case housing?
Maybe I missed it, but what are you using for your frame side crossmember bushings?
Yep, Johnny Joint
Steel sleeved bushing... forgot the one but it came from Poly Performance and fits inside a 1.75 DOM tube
My friends call me "The butcher"
Because I didnt know until now how important this really is.....
Outstanding businesses (going above and beyond) that I have dealt with to date:
Marlin Crawler
Hellfire Fabworks
Daves Offroad
gearinstalls.com (Zuk)
Local 125
Mr Stubs is offline   Reply With Quote
Old 07-15-2012, 07:45 PM   #702 (permalink)
Mr Stubs's Avatar
Member # 102813
Broke up at TSF in the Crushers this weekend.
This netted me three wheel drive. I felt like a fancy man with a ARB in the rear who wasnt smart enough to engage it.
You can check out this thread to get the whole story and the tech behind this problem.
/forum/toyota-truck-4runner/1078757-usa-alloy-rear-axle-length-broke-carrier.html
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 07-15-2012, 11:09 PM   #703 (permalink)
shoes optional
drewp's Avatar
Member # 142117
so you felt like a TJ owner
any wheeling pics fromn the crushers
thanx for linking those other threads on rear inner axle length, thats some good info i never knew, and probably never wouldve questioned
Originally Posted by jimmicee View Post
Dont ruin another sweet toyota by putting a v8 in it. Get a jeep they suck already
drewp is offline   Reply With Quote
Old 07-29-2012, 05:05 PM   #704 (permalink)
Mr Stubs's Avatar
Member # 102813
Went to HooDoo this weekend.
Few pics/vids of the trip
Hornyrednecks new rig
HooDoo 7-27-11 - YouTube
HooDoo 7-27-12 - YouTube
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 07-31-2012, 09:49 PM   #705 (permalink)
Ajs biggest fan!!
RANGERROD's Avatar
Member # 172656
What ever your up too it ought to be good.
/forum/ford/1081928-help-ford-parts-identification.html
RANGERROD is offline   Reply With Quote
Old 09-10-2012, 09:16 PM   #706 (permalink)
Mr Stubs's Avatar
Member # 102813
So I have been burning fuel this summer.... check out the PNW region section for run pics if interested (most have been documented)
Broke my hydro assist clamp and band aid fixed it multiple times. After tearing it completely off the steering rod I welded it on solid this time.
Also seen this....
Now I either have front axle wrap to beat the band or I hooked the front axle on a big rock in a reverse maneuver. Either way I need to keep a close eye on this. I plan on hitting the bare steel spots on the drive line and on the frame with a marker or paint to see if it happens again.
Maybe I should stop playing "follow the leader" with my friends in their buggies?
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 09-11-2012, 02:31 AM   #707 (permalink)
LRC
Member # 203358
when i first got my rig the po had some weird off brand wicked tall springs on it and the front d shaft had a stupid steep angle and hit in all same places as shown on yours but had rubbed soooo much it went through and contacted the pinion flange surface. .
yours didnt seem to hit all that bad, but some slight shaving with a dremel tool may solve it or a anti wrap on the front (if you don't have it already i don't recall) it is caused by excess droop and or axle wrap tho like you said. most likely a combo of both.
im sure you already know this but i like to think i can help people sometimes. ha.
LRC is offline   Reply With Quote
Old 09-11-2012, 03:50 AM   #708 (permalink)
Dick Head
jroach3210's Avatar
Member # 166048
Whats the deal with the washers on the case cross member? What thickness wall did you use for the square tubing?
99 4runner 3.4 5spd boosted and locked
79 pickup 2rz, w56, dualed, e-locked, caged and injected
Build Thread-ish /forum/toyota-truck-4runner/1027555-betty-79-build.html
jroach3210 is offline   Reply With Quote
Old 09-11-2012, 06:07 AM   #709 (permalink)
Mr Stubs's Avatar
Member # 102813
They are there to allow wiggle room for the T case once it is removed. Very hard to pull the splined cases apart when you have a mount that is horizontal instead of vertical.
I don't remember on the steel size. I may have mentioned it earlier in the thread when I built it.
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 09-11-2012, 08:19 AM   #710 (permalink)
Wilson's Avatar
Member # 7233
Do you run limit straps?
[COLOR=Red][SIZE=4]ECV 7-11[/SIZE][/COLOR] Serving up a Tsunami of Swagger
Wilson is offline   Reply With Quote
Old 09-11-2012, 08:10 PM   #711 (permalink)
Mr Stubs's Avatar
Member # 102813
No, but am considering them now if this problem persists.
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 09-16-2012, 08:20 PM   #712 (permalink)
Mr Stubs's Avatar
Member # 102813
Back from another run at Swartz... check out more pics and vid here if interested..
http://www.pirate4x4.com/forum/showt...3#post14799213
These leafs are really getting on my nerves... I have been running my bent rear pack on the drive side but now I put my pass side rear through the wringer....
As for the front... my "check it to see if it happens again" marks show that I have axle wrap enough to put the shackle into the frame and bind the front joint in the driveline.....
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 09-16-2012, 08:30 PM   #713 (permalink)
Wilson's Avatar
Member # 7233
Why are you assuming wrap? Scratch marks on the frame read articulation/ bushing issues to me. Ujoints read similar (need limit straps). I ran straps to save my leafs. Overwork them and bad stuff can/ will happen. Most that I see running straps with leafs do so to save the shock, I will also argue that is the wrong approach. As for your rears.... Probably time to link
Old 09-16-2012, 08:53 PM   #714 (permalink)
Mr Stubs's Avatar
Member # 102813
PM sent....
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 11-10-2012, 04:21 PM   #715 (permalink)
Mr Stubs's Avatar
Member # 102813
Well progress has been nil. No motivation, low funds, blah, blah, blah......
But I ran into another problem altogether....
4 39" red label Krawlers showed up in the shop........
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 11-10-2012, 04:26 PM   #716 (permalink)
Mooseknuckle OG
85dhor's Avatar
Member # 139159
haha
"You break on the trail, You BECOME the trail!" - drunk guy
MY BUILD http://www.pirate4x4.com/forum/showt...083&highlight=
85dhor is offline   Reply With Quote
Old 11-10-2012, 05:18 PM   #717 (permalink)
tanzuki's Avatar
Member # 15771
Send a message via ICQ to tanzuki Send a message via AIM to tanzuki Send a message via Yahoo to tanzuki
I know there is no video with audio but I swear I can hear those axles screaming bloody murder in the background. Also some laughing more than likely from the HP60. ;-)
YO YO HA!!!
tanzuki is offline   Reply With Quote
Old 11-10-2012, 05:50 PM   #718 (permalink)
crash's Avatar
Member # 1588
Sticky's
Mike Crash Kash
crash is offline   Reply With Quote
Old 11-10-2012, 06:12 PM   #719 (permalink)
papacasey's Avatar
Member # 55254
Built tons are a must if you are going to run those. They laugh at toy axles and spit out little metal pieces.
85 Runner with some stuff.
papacasey is offline   Reply With Quote
Old 11-10-2012, 06:13 PM   #720 (permalink)
papacasey's Avatar
Member # 55254
Do it!
Old 11-10-2012, 07:13 PM   #721 (permalink)
Member # 89727
Bummer...feel like donating your old tires to a poor 1st Gen guy?
1981 Toyota Trekker 220:1
ocdropzone is offline   Reply With Quote
Old 11-10-2012, 08:39 PM   #722 (permalink)
Member # 135403
nice build
Birdman69 is offline   Reply With Quote
Old 11-10-2012, 08:48 PM   #723 (permalink)
Member # 166881
All that traction might be unsafe with bent leaf's. I'll hold on to them for a while, my rigs not running yet, don't worry
Chilkat is offline   Reply With Quote
Old 11-11-2012, 07:58 PM   #724 (permalink)
high off aluminum
kiyul4130's Avatar
Member # 37026
Your bushings blown? Looks like your shackle hit and rubbed hard against the frame? did you check the inside of that shackle for wear? I know my old stuff was pretty bad at times and moved all OVER the place. forward and back, side to side....you name it.....it happened but still held up fine. (not saying that its ok one bit). It was me being lazy on my behalf 100%.
ECV 7-11
KYOTA Forever
kiyul4130 is offline   Reply With Quote
Old 11-11-2012, 08:18 PM   #725 (permalink)
Mr Stubs's Avatar
Member # 102813
No, the bushings are good.
My front axle is walking so far forward that it is doing that to the frame with the shackle and binding my front drive line.
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
