Blueberry Krunch - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-11-2009, 04:24 PM   #51 (permalink)
Mr Stubs's Avatar
Member # 102813
I ran the suspension down to full droop. After measuring I should have 11" of travel from full compression to full droop at the spring to frame.
My friends call me "The butcher"
Because I didnt know until now how important this really is.....
Outstanding businesses (going above and beyond) that I have dealt with to date:
Marlin Crawler
Hellfire Fabworks
Daves Offroad
gearinstalls.com (Zuk)
Local 125
Mr Stubs is offline   Reply With Quote
Old 01-11-2009, 04:29 PM   #52 (permalink)
Mr Stubs's Avatar
Member # 102813
Also got the bump stops remounted and started on the tank holders.
I priced out bumps and my wallet started to squirm, so I just recycled.
(Angled just like you suggested Lowtorious)
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 01-24-2009, 06:32 PM   #53 (permalink)
Mr Stubs's Avatar
Member # 102813
I am close to finishing the pane tank holders. The only thing that I really need to do now is mount the tank clamps. I cant do that right now since will have problems setting the body on if I do.
I made these pins to help hold the tanks in place. My reasoning for them is that they are used on forklifts to keep the expansion safety valve up and the pick up tube down. It will also be a back up holder if the tank clamp comes undone during a rollover.
I also made these bump stop strike plates. I like this type because it puts a double nut on the U-bolts. This will keep the nuts from working loose over time.
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 01-25-2009, 09:57 AM   #54 (permalink)
Registerd User
Kiwipushrod's Avatar
Member # 109586
Hey Stub's,
I've been watching the Krunch build since the beginning, I like everything You've done soo far, Nice skills/work.
I have a question about the double nut plate setup for the axle ubolts, it will keep the nut's from loosening.
But is'nt the reason for them loosening, the fact that the ubolts themselves actually stretch and not the nuts rotateing on the threads. So did'nt You just make it harder to tighten them?
Kiwi
Almost forgot,
Kiwipushrod is offline   Reply With Quote
Old 01-25-2009, 10:50 AM   #55 (permalink)
DuCaTi MoNsTeR
Booger Weldz's Avatar
Member # 2931
i think he did that because the leaf spring centerpin will chew up his bumpstop as it hits it over and over...i would hve just cut the centerpin off flush with the top of the Ublt plate so he doesnt have to deal with what you described above??
Amongst the best of the toyota vendors:
Www.4wheelunderground.com
Www.addictedoffroad.com
Www.hellfire-fabworks.com
Booger Weldz is offline   Reply With Quote
Old 01-25-2009, 10:53 AM   #56 (permalink)
DuCaTi MoNsTeR
Member # 2931
i shoulda trimmed the body mount like you did for the shackle mount clearance...good thinkin! mines a bit steep, as i got greatly moving the axle forward, but im trying to hold up the 3.0 v6 and some fat girls...
Old 01-25-2009, 11:23 AM   #57 (permalink)
Mr Stubs's Avatar
Member # 102813
I want to keep the center pin long since I will be experimenting with the rear leaf pack. I dont want to go and buy new pins every time I want to add a leaf or cut them if I take a leaf out.
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 01-25-2009, 11:33 AM   #58 (permalink)
Mr Stubs's Avatar
Member # 102813
Did I make it harder to tighten? Yes.
Do they stretch and loosen? Yes.
I think that once the u-bolt has stretched a little it gives room for the nut to start to work loose. Since the nut has another on top of it with the plate between (plate can not turn with the nut) it is unable to work loose. It will only let the spring get as sloppy as the stretched u-bolt will let it and not the combination of the bolt and the nut.
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 01-25-2009, 11:39 AM   #59 (permalink)
DuCaTi MoNsTeR
Member # 2931
good point
Old 01-25-2009, 11:46 AM   #60 (permalink)
Mr Stubs's Avatar
Member # 102813
I awoke to snow on the ground today so the body isn't going back on today.
I decided to start on my next headache. I bought this front axle a while ago ( before the prices on used stuff got real good ) along with the rear that I am using. The more I look at it the more I wonder why the hell did I buy this thing. It is loaded with great parts but the fab work is a bit to be desired.
Hydro assist ram angle is way out of line and mounts are, well,
Knuckle gussets. Better to clearance the felt and ring than the gusset itself.
I need to repair the pass side perch. The spring pin hole has been elongated.
Now can anyone see to two problems here?
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 01-25-2009, 11:55 AM   #61 (permalink)
Registerd User
Member # 109586
The caliper mounting bolt is bent and hitting the rotor?
Are we going to be graded on a curve?
Kiwi
Old 01-25-2009, 12:13 PM   #62 (permalink)
Mr Stubs's Avatar
Member # 102813
Kiwi
"F" is for FAIL.
Next...... or do you want to try again?
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 01-25-2009, 12:32 PM   #63 (permalink)
Registerd User
Member # 109586
No Mr Stubs,........Can You call on dopeass, He knows the answer.
Kiwi
Old 01-25-2009, 06:33 PM   #64 (permalink)
we can go that way
billybob13's Avatar
Member # 85972
the problem i see is toyota brakes on a semi floater. need a ff or chevy calipers.
FJ80 HIGH STEER KITS /forum/axles-tires-wheels/997804-fj80-high-steer-way-you-need.html
Authorized ruffstuff dealer- pm me for pirate discount and free shipping!
pm me for affordable built toyota 3rd members or parts!
ADS racing shocks- i can save you money on those too!
billybob13 is offline   Reply With Quote
Old 01-25-2009, 06:54 PM   #65 (permalink)
Mr Stubs's Avatar
Member # 102813
This problem is on a front axle...
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 01-25-2009, 07:03 PM   #66 (permalink)
we can go that way
billybob13's Avatar
Member # 85972
it's all that crack i smoked for lunch today
FJ80 HIGH STEER KITS http://www.pirate4x4.com/forum/showthread.php?t=997804
Old 01-25-2009, 07:04 PM   #67 (permalink)
Mr Stubs's Avatar
Member # 102813
Kiwi
"F" is for FAIL.
The front is set up in a old school IFS hub conversion that doesn't use the Sky spacers http://www.sky-manufacturing.com/new...uct.php?id=127
This is a messed up way of doing it because the rotor and caliper can not be taken off until the wheel bearing is removed. The guy that I bought it from must had been drunk with no patience. The caliper pad was installed backwards (steel to the rotor) and ran that way. Wheeling must had been more important the next day than disassembling the wheel unit and switching around the pad.
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 01-25-2009, 07:06 PM   #68 (permalink)
YOUNG BEN's Avatar
Member # 26340
looks like the caliper is on the wrong side of the mounting ears on the knuckle and the rotor is spaced away from the hub body
96 4runner 44,14B on 39s
YOUNG BEN is offline   Reply With Quote
Old 01-25-2009, 07:32 PM   #69 (permalink)
Member # 108283
i used FJ rotors with 4 piston calipers with the ifs hub swap. had to use the stock ifs rotor to mark FJ rotors where to drill for mounting to the ifs hub. then tapped calipers with 1/2'' fine thread tap,drilled out knuckle where bolts went through to caliper. you have to also mill a little material off of calipers tabs so they don't rub on rotor. also make sure to use grade 5 bolts because they have a higher shear strength than grade 8.
jackson58 is offline   Reply With Quote
Old 02-07-2009, 06:36 PM   #70 (permalink)
Mr Stubs's Avatar
Member # 102813
So I have sent a bunch of time cleaning and disassembling this front axle. What a mess.
I lowered the spring perches as much as I could. 1/4" is all that is possible.
Then I had a fellow Pirate member suggest lengthening the perches to combat axle wrap.
Then I started on the 5th stud mod. Bobby Long style.
This is the sweet spot to drill, dead center of the two casting lines.
I had a lot of drive line bolts laying around and they turned out to be the perfect length with a piece of 1/4". Smoothed out the top of the knuckle for a good flat fit.
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 02-07-2009, 09:13 PM   #71 (permalink)
Maroon Monsoon's Avatar
Member # 95108
Send a message via AIM to Maroon Monsoon Send a message via MSN to Maroon Monsoon
I love the idea of lowering the spring perches. I think the front of my truck sits a bit high and it's nice to have that as an extra option in mind. I just might give that a try one of these days... 1/4 inch isn't much though, but definately worth it if the axle is already off the truck for something esle.
once again, great work on this rig.
86 yota pickup:[url]http://www.pirate4x4.com/forum/showthread.php?t=632103[/url]
Maroon Monsoon is offline   Reply With Quote
Old 02-08-2009, 09:54 PM   #72 (permalink)
Erick561's Avatar
Member # 100293
Send a message via AIM to Erick561 Send a message via MSN to Erick561
I have a question for your Post #12; how high did you raise the steering box with this mod?
'79 Toyota Hilux DD - Project NutKase
http://pirate4x4.com/forum/showthread.php?p=9337997
'87 2wd Toyota Pickup, 32/36 on the back burner
Erick561 is offline   Reply With Quote
Old 02-09-2009, 05:50 AM   #73 (permalink)
Mr Stubs's Avatar
Member # 102813
I dont remember exact measurements, but the lowest bolt hole was drilled almost to the top of the frame.
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 02-17-2009, 08:35 PM   #74 (permalink)
Mr Stubs's Avatar
Member # 102813
So I have spent a bunch of time cleaning parts, painting parts, deciding what parts to buy, ext, for the last few days.
I cut off and replaced the shock mounts and capped the bent steering stops.
I had a 4 cyl front diff with a Lock-Rite and 4:11s in the front and a welded V-6 diff with 4:11s in the back. I didnt want to kill the rear output shaft so I started to check out prices on R&P. I have set up gears before so I figured it would not be to much trouble again. But typical of me, this followed me home from a Craigslist add. Both have Detroits and 5:29s with Yukon gears. The set up paint is still fresh.
This was thrown into the mix as well!!!! New 30 spline with the 40*
Now that I have more than one pair for this truck do you think I can double them up for extra strength?
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
Old 02-18-2009, 07:50 PM   #75 (permalink)
Mr Stubs's Avatar
Member # 102813
Welded the 5th stud nut to the inside to the knuckle and tack welded the top steering knuckle studs (along with red lock tight)
I have had studs work loose before even with red lock tight. I think that studs break because they work loose first.
Marlin Crawler
Hellfire Fabworks
Daves Offroad
Local 125
