Project: SupraRunner 2jzgte swap - Page 8 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-08-2010, 08:01 PM   #176 (permalink)
Member # 37728
That sucks about the engine... but now it gives you a chance to build it a lot stronger. Make sure to take plenty of pics.
I got nothing...
wslytoy82 is offline   Reply With Quote
Old 02-08-2010, 08:48 PM   #177 (permalink)
bigtoy302's Avatar
Member # 36440
Hopefully soon after my press brake is done I will get back on the project.
bigtoy302 is offline   Reply With Quote
Old 04-19-2010, 07:26 PM   #178 (permalink)
rockn yota's Avatar
Member # 122498
Ttt
any updates? it has been a while since we have heard from you. i start tomorrow on my 1jzgte swap into my 87' prerunner
rockn yota is offline   Reply With Quote
Old 04-19-2010, 07:34 PM   #179 (permalink)
bigtoy302's Avatar
Member # 36440
Still parked. I have been rounding up parts to build a 609 front though. I have been busy trying to get my business started. As soon as funds allow I will get back on this project.
Old 04-19-2010, 07:55 PM   #180 (permalink)
burnt-kat's Avatar
Member # 8325
Send a message via AIM to burnt-kat
damn, think I just came a little from that video....
updates?
burnt-kat is offline   Reply With Quote
Old 07-25-2010, 07:59 PM   #181 (permalink)
bigtoy302's Avatar
Member # 36440
last week I decided to work on it again. I did a compression test and found that cylinder 2 and 3 only had 90lbs of compression. I then did a leak down test and found that the head gasket was blown. So I decided to take the head off and have a look. The head gasket had a .060" piece missing between 2 and three and all the other cylinders where almost blown through. I checked the head and found it was warped about .010". I took it to work and milled it flat again. I also found that the exhaust stem seals where just floating on the valves and not even attached to the head anymore. The intakes where still attached but where all hard and broken. So I bought some viton seals and installed them. I tossed a new head gasket in and now she purrs like a kitten. No more smoke and it runs good. It still makes a weird ticking sound when cold at light load almost like its pinging but goes away when warm. I still need to play with the timing and see if that fixes it.
Yesterday I threw my paddles on and headed to the coast. This thing is a absolutely terrifying in the sand. 2nd gear launches at redline are awesome. I only played for about a hour and my tire went flat.
Old 07-25-2010, 08:25 PM   #182 (permalink)
Member # 153061
thats great. the fact that it looks stock for the most part is my favorite part. ive got a similar looking 4runner with the 3.slow...and that video gave me goosebumps.
byron4 is offline   Reply With Quote
Old 08-08-2010, 08:05 PM   #183 (permalink)
bigtoy302's Avatar
Member # 36440
Chase cam video from this weekend. Everything ran good but the same paddle went flat again at the end of the day.
YouTube - ‪92 4runner, 2JZ, HX 35‬‎
Old 08-09-2010, 05:15 PM   #184 (permalink)
rapier46's Avatar
Member # 165420
mmmm 2jz....
Toyota punishment
rapier46 is online now   Reply With Quote
Old 08-10-2010, 08:52 PM   #185 (permalink)
Member # 166072
i go faster on ur mom.... no really...
looks fun! good job!
fishfood is offline   Reply With Quote
Old 08-10-2010, 10:14 PM   #186 (permalink)
x91crawlerx's Avatar
Member # 165794
nice swap!
Good thing my parents grass was EMO never had to cut it!
x91crawlerx is offline   Reply With Quote
Old 08-10-2010, 10:58 PM   #187 (permalink)
Member # 136011
His mom's probably a red head then?
Romix is offline   Reply With Quote
Old 08-11-2010, 08:05 AM   #188 (permalink)
Member # 166072
has to be... good guess!
Old 08-11-2010, 08:32 AM   #189 (permalink)
Whatever VS sez
Roc Doc's Avatar
Member # 20631
If the ticking goes away when it's warm, I'd doubt that it's ignition related, more likely something mechanical (duh), whose tolerance tightens up when it gets warm. Maybe something in the valvetrain, eh?
Did you check compression when you got the engine? If it was good and you blew the gasket, then you could be getting some ping. Does your MS pull out timing under boost?
Awesome build and fab skilz I can only dream about. Props.
“To be a warrior is not a simple matter of wishing to be one. It is rather an endless struggle that will go on to the very last moment of our lives. Nobody is born a warrior, in exactly the same way that nobody is born an average man. We make ourselves into one or the other.
" - Carlos Castaneda
Roc Doc is offline   Reply With Quote
Old 08-11-2010, 10:45 AM   #190 (permalink)
Member # 81939
holy crap man that is a sic runner!!!
hamish_18 is offline   Reply With Quote
Old 08-11-2010, 04:00 PM   #191 (permalink)
bigtoy302's Avatar
Member # 36440
I did not check compression when I got it. I am pretty sure it is pinging when cold which does not make a whole lot of sense. It only does it at light load between 10-15 inches of vacuum when cold. It goes away after it is warm. If I add more timing in those spots the noise continues even when warm. I can not run over 30 degrees timing under cruise or it pings. I pull about 1 degree of timing per pound of boost under load. It does not ping in boost.
Old 08-12-2010, 04:19 PM   #192 (permalink)
Member # 160081
Originally Posted by Okiyota View Post
Sounds cool, wish i could find someone to buy my VVTi 2JZ thats sitting in my garage.
How much? I wouldnt mind putting that in my RX-7... Im in Colorado.
84skinner is offline   Reply With Quote
Old 08-12-2010, 08:50 PM   #193 (permalink)
bigtoy302's Avatar
Member # 36440
I was helping a friend dyno a rabbit tonight at Garage 808, so after that we decided to throw the runner on the dyno real quick. I did not have time to tune but I will put it back on when I get MS3 on. It made 357hp and 340FT-LBS at 15psi.
Old 08-12-2010, 10:24 PM   #194 (permalink)
bigtoy302's Avatar
Member # 36440
Dyno video
YouTube - 2jz 4runner dyno
Old 08-18-2010, 08:16 PM   #195 (permalink)
Member # 142043
That's sexy. Kudos to your amazing fab skills and creativity.
I've got a '91 runner that I want to put a 5.7 Tundra motor and 6-speed auto into, if I ever get it done we ought to "see who's faster"
Off topic: How much do they charge to do a dyno run?
TenTundra Build [url]http://www.pirate4x4.com/forum/showthread.php?t=857796[/url]
NateK is offline   Reply With Quote
Old 08-18-2010, 08:31 PM   #196 (permalink)
bigtoy302's Avatar
Member # 36440
I think it is around $80 for 3 pulls. I have not paid him yet. I coat pistons for him so I am sure he will get me back.
Old 08-18-2010, 08:42 PM   #197 (permalink)
Behind the Lens
SiRMarlon's Avatar
Member # 146172
Send a message via AIM to SiRMarlon
Dude! That is so sick!!!
-Marlon
"Like" us on Facebook! - https://www.facebook.com/SiRMarlon.Photography
SiRMarlon is offline   Reply With Quote
Old 08-19-2010, 08:24 PM   #198 (permalink)
shoes optional
drewp's Avatar
Member # 142117
i just felt a little tickle in my pants after watching your dyno vid, nice job man
Originally Posted by jimmicee View Post
Dont ruin another sweet toyota by putting a v8 in it. Get a jeep they suck already
drewp is offline   Reply With Quote
Old 08-22-2010, 11:30 PM   #199 (permalink)
Member # 142043
Just looked at your pic again... Will a fullsize fit on the rollers?
Old 08-23-2010, 06:04 AM   #200 (permalink)
bigtoy302's Avatar
Member # 36440
I am pretty sure he has put 1 ton crew cab diesels on it before.
