37" MTR's NO LIFT! Will I build it? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-13-2009, 10:27 PM   #1 (permalink)
MedicDB's Avatar
Member # 56067
I am tooling around with the idea of going up to 37/12.50/15 Goodyear MTR's on my 85 X-cab with NO LIFT. (Well More like planning) I currently have 33/12.50's and got them working great with full flex using the stock leafs and only minor rubbing at full wheel lock. I have 2 E-lockers I am rigging with 5.29's and a doubler waiting to go in. My big question is how much cutting do you think it will take to make them work? I Searched and only found one NO LIFT IFS build with 38 swampers but in the end it looks like he lifted it and went SAS. I have the means,tools, and willingness to cut my beloved truck just want an idea of what it will look like and how much cutting/tubbing I am signing myself up for. If any of you know of a build I can look at for ideas please let me know. Also let me know of any problems I am not thinking about.
Plans for build to be done before Easter Moab.
Build rock rails (DONE)
Build Exo (Gonna wait till I get a better bender)
T-case doubler (DONE)
Build new X member (Bought one instead)
Cut rear end for E-locker (Front and Rear E-lockers DONE)
Cut and rebuild bed (Kinda Done for now)
Tub front end for tires/ cut firewall (Did enough cutting for now but will cut more later for 1 1/2" spacers)
Yea I'll probably buy a new star again and post some pics.
How it looked as of 2/09
Teaching the escelator a lesson!
POTATO SALAD!
YouTube - Paramedic up Potato Salad
How it looked after the 37's NO LIFT Build
How it looks as of 4/16/11 with about 2" of lift RUF/F-250's Rear and a partial exo:
When I am not driving one of my rigs I'm pickin your busted a$$ up in my Ambulance!
My 85 Toyota truck build "37's NO LIFT"
MedicDB is offline   Reply With Quote Quick reply to this message
Old 02-13-2009, 10:29 PM   #2 (permalink)
Member # 95669
I'm not positive, but I'm guessing that you are probably the ONLY one to do this.
get a damn star and show us
A day without Megadeth, is a Megadon't.
seandnw is offline   Reply With Quote Quick reply to this message
Old 02-13-2009, 10:37 PM   #3 (permalink)
Member # 86771
Dont you know how to search without a red star yet? Move the axle forward as much as possible and start cutting. 37s why such a small tire? Dont buy anything just make it yourself. What kind of welder do you have?
tomjordanphoto is offline   Reply With Quote Quick reply to this message
Old 02-13-2009, 10:43 PM   #4 (permalink)
Member # 128345
The hardest thing is going to be your steering. All you have to do to fit the tires is cut sheet metal. The solid axle frame will help you in this regard but you will probably have to lift it a little bit if you want much uptravel.
You plan on running highsteer right?
dniel is offline   Reply With Quote Quick reply to this message
Old 02-13-2009, 10:49 PM   #5 (permalink)
76chevy's Avatar
Member # 115967
good luck moving the ifs forward. or you will have to cut into the cab ot make room for the 37's.
a friend of mine has a 84 runner with 2 in body and 38's. it goes nice.
76chevy is offline   Reply With Quote Quick reply to this message
Old 02-13-2009, 10:52 PM   #6 (permalink)
Member # 2155
'85 dude.....no IFS!
Guff "Luck favors the prepared"
1982 Toyota LWB, 3.4/auto, 4.7 duals, cage, flatbed, longs,40" MTRs,etc..
1994 FZJ80 Landcruiser
2003 Ram 2500
I see a bunch of vaginalistic pussy assed fawktards............
MT-Toy is offline   Reply With Quote Quick reply to this message
Old 02-13-2009, 10:57 PM   #7 (permalink)
MedicDB's Avatar
Member # 56067
My welder is a Hobart Handler 175. I like the idea of moving the axle foward and may go that way. The money is a little tight so I will need to prioratize my spending. The gears and tires will wipe most of my budget but I will make what I can to save some coin. Do you guys think my stock birfs can hold if I crawl it and stay off the gas? I am not sure I can affored longs yet. However I do have my old Sammi truggy to sell? got to get working on that.
Old 02-13-2009, 11:07 PM   #8 (permalink)
Fawk Awph's Avatar
Member # 26857
Send a message via MSN to Fawk Awph
rears up front, lose a leaf = no lift. good bumps and limit straps, redrill your perches forward as much as possible (1") either go IFS steering box and hack the fuck out the the body mount with crossover or just go full hydro with a LR orbital and a nice double ended ram. then your have to tub your firewall for sure with leafs.
or
depending on what you call NO LIFT you could just link it. im at 25.5 on 42s. . .so that would be 23 on 37s.
what is your frame height with the 33s?
ECV 7-11
Fawk Awph is offline   Reply With Quote Quick reply to this message
Old 02-14-2009, 12:04 AM   #9 (permalink)
Mr Stubs's Avatar
Member # 102813
You can do it... picks of a friends 84 with OME 2.5" lift (after a few years of hard wheelin they are flat) with Q 78s
Sawzall baby!!!!!!!!!
Help bring back Swartz Canyon, Join
The good guys...
Marlin Crawler, Hellfire Fabworks, Dave'z Offroad, gearinstalls.com (Zuk), Diamond Axle, RADesigns, Advanced Adapters, Jantz Engineering, G-Fab motorsports, Got Propane, JHF
Mr Stubs is offline   Reply With Quote Quick reply to this message
Old 02-14-2009, 12:22 AM   #10 (permalink)
vichayb's Avatar
Member # 44100
mr. stubs did you shaved your legs?
vichayb is offline   Reply With Quote Quick reply to this message
Old 02-14-2009, 12:25 AM   #11 (permalink)
Mr Stubs's Avatar
Member # 102813
No, do I need to?
The good guys...
Old 02-14-2009, 12:27 AM   #12 (permalink)
Member # 85972
um, in the last pic, is there more where that came from or are you just teasing us?
and to the op, just start cutting and do it. cut out the inner fender wells at the battery tray and airbox. relocation for both is necessary. steering box (ifs) should be about 3" forward. if you know toyotas you know the rest here.
I'm not on Pirate much anymore, but you can find me on here-
And yes I still have lots of build parts for sale! New website coming soon!
billybob13 is offline   Reply With Quote Quick reply to this message
Old 02-14-2009, 12:42 AM   #13 (permalink)
Member # 45196
stock suspension/no lift = a low good fuctioning, stable, flexible suspension that clears the tires and controls axle wrap is where its at
96 taco, lockd, linkd, caged, beat, daily driven 24" frame on 4dz ready to jump
toy86 is offline   Reply With Quote Quick reply to this message
Old 02-14-2009, 12:59 AM   #14 (permalink)
Member # 85972
what's so gay about no lift?
give us your idea of the ideal set up please.
Old 02-14-2009, 01:14 AM   #15 (permalink)
a2b
a2b's Avatar
Member # 22547
gay thread
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote Quick reply to this message
Old 02-14-2009, 09:03 AM   #16 (permalink)
MedicDB's Avatar
Member # 56067
Its funny to me those of you that think my thread is gay and say so (way to get your post count up!). I have been on and off this board for years and although I have seen lot of builds I did not think where the best I never made a bad comment. We all have our own ideas of what works. Where I wheel low center of gravity is a big priority to me. This is also my dd so super flexy suspension is not ideal. I have had a crazy over built rig with lots of flex and don't want it any more. And truth is I like to keep some of the challenge in my wheeling otherwise the fun is lost! Don't worry I am not all butt hurt! Anyway any of you looking to buy a truggy?
Old picture of my other rig about to go for sale to fund this build. I lost a lot of my other pics of it and pulled this from the web. It is now 15" longer than in this old photo. That was the escelotor teaching me a lesson back then!
Old 02-14-2009, 09:29 AM   #17 (permalink)
Member # 13707
I have about 5" of lift on my 85 with 37 mtr's. The only problem I have is the tire still hits the inside fender well at full stuff. You will have to tub the cab big time to clear.
Rears up front, moved front axle almost 2" forward.
Toyoda is offline   Reply With Quote Quick reply to this message
Old 02-14-2009, 09:33 AM   #18 (permalink)
84Xcab's Avatar
Member # 108503
http://www.tacomaterritory.com/forum...ighlight=stock
84Xcab is offline   Reply With Quote Quick reply to this message
Old 02-14-2009, 10:04 AM   #19 (permalink)
MedicDB's Avatar
Member # 56067
Thanks for that last link exacly what I have been looking for! based on those pics looks like I will definatly need to move the front foraward a couple inches! I was hoping to avoid that but O'well longer wheelbase = better climbing!
Old 02-14-2009, 10:31 AM   #20 (permalink)
Member # 44451
Do it!!! Im running a 3 inch lift with 38.5's the front is moved 3 inches foward to clear the firewall, I like the idea get a 10 degree rotated adapter for your doubler if you can and go with a front range mount and skid to save as much room underneath as possible, I would even hack the tunnel a little and make it completely flat underneath it only needs about 1.5-2 inches after you get the r10 adapter and front range skid plate... Run rears up front and dont add any more leafs it will only lift you about a 1/2 inch to an inch, if you loose a leaf it may not lift it at all but would make the front kinda scary soft so Id stick with letting it lift you an inch or 2... get some 3rd gen 2wd truck rear main leafs and build a pack for the back dont get the 4wd ones...there a little longer than the 2nd gens and flex good and the spring still wraps off the bottom of the eye use your double wrap 2nd spring from your pack still and bend the shackle end flat because the new main is longer... it will make for a good stable low truck and will wheel great and still flex well... also it will ride really nice. my steering box is so far forward it comes thru the radiator support, so getting your axle foward in the front is important.... Used2ba83 has a almost stock height 4runner stretched wheelbase on 36's and it works awesome screw the haters that think its gay
85'Xtdcab R10 duals,FROR Xmember,Thorley header,Hybrid leafs,38.5" Swampers
caliyota420 is offline   Reply With Quote Quick reply to this message
Old 02-14-2009, 10:33 AM   #21 (permalink)
4rnr's Avatar
Member # 34860
Originally Posted by a2b View Post
gay thread
Understatement.
I come here to get AWAY from yotatech. Does a man have no place to hide these days.
92 4rnr 3.4 auto duals 37's...
72 fj40 some stuff.
4rnr is offline   Reply With Quote Quick reply to this message
Old 02-14-2009, 11:14 AM   #22 (permalink)
Member # 45196
at no lift you will have very shitty approach and departure angles, your breakover angle will be even worse especially with the ex cab. your stock suspsension isnt going to have any flex so even though you have a sumwhat low COG its not going to feel that nice going through big rocks
Old 02-14-2009, 12:29 PM   #23 (permalink)
Member # 3132
with 37" tires in the front, no lift with a rear spring up front and flat springs at the bottom will make for a really good approach. with a bed bob the rear will not be so bad either. but leaving all that drive train down there in a lwb is probably not all that great of an idea without some good skids and a belly tuck.
it can be done. but easier i think on a 1st gen with the bigger wheel wells.
Old 02-14-2009, 01:56 PM   #24 (permalink)
Member # 79934
Send a message via MSN to knixen
long time ago on my gen 2 runner, no lift and 37s...
Knixens runner... diesel, the works... :laughing:
knixen is offline   Reply With Quote Quick reply to this message
Old 02-14-2009, 02:03 PM   #25 (permalink)
high off aluminum
kiyul4130's Avatar
Member # 37026
didnt he just tell you what an ideal setup was before you quoted him......
ECV 7-11
KYOTA Forever
kiyul4130 is offline   Reply With Quote Quick reply to this message
