22r torque specs - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-30-2009, 05:48 PM   #1 (permalink)
Member # 48605
Send a message via MSN to goblin79 Send a message via Yahoo to goblin79
22r torque specs
hay uall i need to know what the torque specs are for the main and rod caps on a 84ish 22r
Yota cab truck 3 in body lift and 2.5 Pro-comp spring lift welded rear with Trail Gear doulbler,Trail Works sliders, GLO dyi bead locks, 36 in iroks, bull dog 8k winch
join the game
[url]http://game.pirate4x4.com/register.php?ref_id=4358[/url]
goblin79 is offline   Reply With Quote
Old 03-30-2009, 06:01 PM   #2 (permalink)
Erick561's Avatar
Member # 100293
Send a message via AIM to Erick561 Send a message via MSN to Erick561
Dude if you're all the way down to that part of your engine rebuild, you really should have a manual, just my 2 cents. good luck lol
'79 Toyota Hilux DD - Project NutKase
http://pirate4x4.com/forum/showthread.php?p=9337997
'87 2wd Toyota Pickup, 32/36 on the back burner
Erick561 is offline   Reply With Quote
Old 03-30-2009, 06:02 PM   #3 (permalink)
RTA
Member # 73430
Main 75 ft-lb
Rod cap 43 ft-lb
RTA is offline   Reply With Quote
Old 03-30-2009, 06:03 PM   #4 (permalink)
Member # 48605
im not rebuilding it just ting it back together to try to get buy till i get my other1 rebuilt I'm just redoing the rod barrings it spun 1
join the game
Old 03-30-2009, 06:04 PM   #5 (permalink)
Member # 48605
Originally Posted by RTA View Post
Main 75 ft-lb
Rod cap 43 ft-lb
thx man
join the game
Old 03-30-2009, 06:11 PM   #6 (permalink)
Erick561's Avatar
Member # 100293
Dude he's wrong. 43 FT LBS is for 85+ blocks, you have an 84 block, rod cap is 46 FT LBS, and main bearing cap is 76 FT LBS.
Old 03-30-2009, 06:28 PM   #7 (permalink)
Member # 48605
hell it don't much matter my crank is scared some I'm going to polish it with some emery cloth and get it smooth but I'm not expecting it to work for long but hell it mite last the rest of the year or it mite spin as soon as i start it never know its 20 bucks what the hell but thx man ill atlest get it the tite enuff
join the game
Old 03-30-2009, 06:32 PM   #8 (permalink)
Registerd User
Kiwipushrod's Avatar
Member # 109586
It does'nt matter......once the bearing spins in the rod , the rod is shot, it only takes one knock.
I have shimmed the bottom bearing shell back, with a beer can skin cut to size, lasted about two weeks, 20yrs ago
Kiwi
Kiwipushrod is offline   Reply With Quote
Old 03-30-2009, 06:45 PM   #9 (permalink)
Member # 48605
I'm going to try it i though about changing the rod cap off another moter i got that has a spun bearing also
join the game
Old 01-06-2013, 12:54 PM   #10 (permalink)
Erick561's Avatar
Member # 100293
Kiwi
Fuck
Old 01-06-2013, 01:01 PM   #11 (permalink)
I See You
Provience's Avatar
Member # 138976
Kiwi
Fuck
Don't say you weren't warned in you other thread.
Up is difficult. Down is dangerous.
I Like Bright Colors
Romans 1:28-32
Provience is offline   Reply With Quote
Old 01-06-2013, 02:42 PM   #12 (permalink)
Peow130's Avatar
Member # 123919
Torque specs are between loose and stripped to fuck.
98 Tacoma. Chick paintjob and 33's
51' CJ3A/CJV35-U SBF289, Disk swap, SOA, 3speed
Peow130 is offline   Reply With Quote
Old 01-06-2013, 02:58 PM   #13 (permalink)
Erick561's Avatar
Member # 100293
i guess #3 rod had spun already from my spare block and i didn't know. That's why it was seizing on #3 the whole time
Old 01-06-2013, 03:00 PM   #14 (permalink)
JustDSM's Avatar
Member # 182727
Finger Tight, then back it off 1/2 a turn.
Justin
[B][SIZE="2"][COLOR="Silver"]1983 Toyota Hilux SR5 Short Bed "Issei" 世[/SIZE]
[SIZE="1"]Built for 4wheelin', expedition, camping, and overlanding use[/B]
- 3RZ/W56-C Swap, RUF/63's, Sky's Crossover Steering, 33x12.50 MT/R's, 4.88's, Locked, and some armor & lights[/COLOR][/SIZE]
JustDSM is offline   Reply With Quote
Old 01-06-2013, 03:02 PM   #15 (permalink)
I See You
Provience's Avatar
Member # 138976
Damn, bummer to hear.
Is it still going with the loosely torques cap or did it start making noise again? I am genuinely curious how long it lasted.
My parts truck was claimed to have a bad bottom end when I picked it up and I was excited to try and run it until it blew a rod through the side of the block...unfortunately it was just a bad head gasket and cracked exhaust manifold. Still managed to get ~20 miles blowing smoke until it lost compression and would no longer run/start
Romans 1:28-32
