1993 Pickup - No high beams - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-19-2009, 06:45 PM   #1 (permalink)
Member # 88936
Hi all!
I posted this on another forum and am not having any luck. Maybe the god's of Pirate will shine upon me?
I have a 1993 Toyota pickup. The low beams work fine. When I switch it to high the headlights go off but the inside high beam indicator does light up. If I pull back on the switch to flash the high beams DO come on. The headlights are WAAYY brighter than on low so I am assuming that the headlights both low and high have to be in working order.
Questions.
If my inside switch was bad, would the high beam indicator light still come on? Seems like it should not.
In my Haynes manual there are 2 relays. One labeled headlight relay, one labeled DIM switch. Both are inline to the headlights. Anyone know where the dimmer relay is located?
Anyone have any ideas what I should try?
Thanks!!
[QUOTE=WLD_OTZ;28188050]I googled 'triangulating a circle', and they told me to start in the corner and work outward. It was unpossible. Applying to Obama for more cowbell.[/QUOTE]
ejlarson is offline   Reply With Quote Quick reply to this message
Old 08-19-2009, 07:43 PM   #2 (permalink)
Member # 140806
High beams
Mine done the samething drove me crazy. Got a used dimmer switch ( made with turn signal) and fixed it
georgiatoyota is offline   Reply With Quote Quick reply to this message
Old 08-19-2009, 08:21 PM   #3 (permalink)
4CrawlR's Avatar
Member # 4716
High beam indicator works independent of the headlight combo switch. It actually only indicates that the low beams are not on, as current flows from the headlight relay, through the low beam filament, the high beam indicator to ground as shown in the FSM wiring diagram:
Haynes manuals are never a very good reference, especially for electrical things.
More info:
- http://www.4crawler.com/4x4/CheapTri...l#HarnessTypes
And the problem is typically in the combo switch contacts:
- http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
That is if the low beams work fine and in FLASH mode , both the high and low beams come on together. If so, find the contacts that close for high beams (only) vs. the ones that close for low beams (only) and the ones that close in FLASH mode and go from there. Other common problem is a loose connector for those wires down the steering column.
4CrawlR is offline   Reply With Quote Quick reply to this message
Old 08-19-2009, 08:43 PM   #4 (permalink)
Member # 81923
Send a message via AIM to akaphilly
i had same problem. just replace the whole combo switch or try could cleaning the contacts like 4crawler suggested
akaphilly is offline   Reply With Quote Quick reply to this message
Old 08-19-2009, 10:59 PM   #5 (permalink)
Member # 86359
Send a message via AIM to z28suka
From the cheap tricks website
Jon
SAS'd '89 4Runner SR5 - 4" springs, Hi-steer, Square Shaft, 34" LTBs, 4:56's, Addicted Offroad front/CBI rear bumper, TG sliders, tool box
z28suka is offline   Reply With Quote Quick reply to this message
Old 08-20-2009, 06:04 AM   #6 (permalink)
Member # 88936
Thanks again 4crawler! I think you finally got through my thick skull! I didn't know you were a member here.
I thought you were referring to the switch that rotates when the wheel turns - not the turn signal/headlight switch.
I will clean the contacts and report back!
Old 08-21-2009, 04:53 PM   #7 (permalink)
Member # 88936
Hi again!
Just to close this out it WAS the turn signal/headlight "combo" switch. The contacts looked clean but I filed them anyway, VOILA!! That did it!
Thanks to 4CrawlR!
