80 20r CA Vacumm Diagram - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-28-2009, 01:12 AM   #1 (permalink)
Member # 142758
Hey guys,
I need a Diagram for a 1980 20r Ca emission setup
I took the carb off , Cleaned it, Changed the float and upper gasket and put it back on the truck.
when i put it back on and started it with only the vac advance hooked up it was running. a little bogging when stepped on the gas but thats about all ( figured it was because all the others werent hooked up)
so i got a hold of a Haynes manual. followed the ca diagram and now the truck wont idle ....
when it starts i have to keep my foot on the gas or it will die.
Nizmoh is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 01:14 AM   #2 (permalink)
Member # 78331
If you search you will find what you are looking for. We are NOT here to spoon feed you. Please delete this and repost it in the newbie forum.
dirtchicken is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 01:19 AM   #3 (permalink)
Member # 142758
I did search . a lot of the result were from 2005 - 2006 and the posted images are gone.
Old 10-28-2009, 07:48 AM   #4 (permalink)
SeaBass44's Avatar
Member # 40
then go to vato zone
spend $25 & get the book
you should buy one the day you buy the truck
or if you want instant answers
www.yotatech.com
# 530.532.4529
TTC 2010 1989 BRONCO
-Awesome web development for your business.
SeaBass44 is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 10:48 AM   #5 (permalink)
Member # 78331
They make this thing called Google. Guess what I got when I typed toyota pickup fsm. Please do not ever post in this forum again.
Old 10-28-2009, 11:37 AM   #6 (permalink)
prerunnerrunner's Avatar
Member # 103842
Send a message via Yahoo to prerunnerrunner
I followed this one when my 80 had a 20R and it worked fine.
prerunnerrunner is offline   Reply With Quote Quick reply to this message
Old 10-28-2009, 11:42 AM   #7 (permalink)
Member # 142758
www.yotatech.com
I have the haynes manual. That's the problem. The truck was fine without the vacuum lines hooked up. Now when i followed exactly what that book said .. the truck wont idle now....
Thanks for the link, ill try over there.
I'm new to the forum.. not the world of google .. Of course i googled before i made this post. what did you find when you searched for that ? because all i got was 1984 and later 22re manuals .
the one manual i found that said it was for 1979-85 had nothing about the 20r in there http://www.ncttora.com/fsm/index.html
Old 10-28-2009, 11:44 AM   #8 (permalink)
Member # 142758
[QUOTE=prerunnerrunner;10504090]I followed this one when my 80 had a 20R and it worked fine.
Thank you ! i'm gunna go through this and see if its any different from the diagram i have
Old 10-29-2009, 04:29 PM   #9 (permalink)
Erick561's Avatar
Member # 100293
Location: I ship from New London County Connecticut & Undercut
Send a message via AIM to Erick561
wouldn't an 80 20r not have to pass emissions anyways?
Erick561 is offline   Reply With Quote Quick reply to this message
Old 10-29-2009, 04:37 PM   #10 (permalink)
SeaBass44's Avatar
Member # 40
nope
1975 & earlier presmog, 1976 & later must smog, thanks to the goverator, there used to be a rolling 25 year or older law, he stopped it
# 530.532.4529
Old 11-01-2009, 08:32 PM   #11 (permalink)
Member # 511
It's the best I could do with my cell phone.
1/17/09 - Updated with higher quality photo.
bbrennan is offline   Reply With Quote Quick reply to this message
Old 11-02-2009, 01:48 AM   #12 (permalink)
Member # 142758
Sweet, thank you for the picture. My Diagram sticker is all washed out.
Old 11-20-2009, 04:37 PM   #13 (permalink)
Member # 143073
80 20R CA Vacumm Diagram
Well did that work for you? seabass & dirtchicken were awfully harsh, hope they diddn;t sour your taste on this, usually helpful forum. There's usually 10% jerks in any one place, too bad you had to be greeted by both of em on your first post. I'd like to give them my famous Marine Corps welcome, one at a time or both at once. Good luck to YOU lad.
I'm old school, if I can climb on it, I can wheel it.
letsgo is offline   Reply With Quote Quick reply to this message
Old 01-17-2010, 01:25 PM   #14 (permalink)
Member # 511
Nizmoh, if you're still watching this thread, I just updated my post above with a much better/clearer picture. If you take this image to a print shop they might be able to make you a new one.
