22RE head gasket - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-12-2009, 06:03 PM   #1 (permalink)
Member # 14600
22RE head gasket
Okay, I'm kicking myself! About 20,000 miles ago I replaced the worn out motor in my '85. My buddy had a good used (recently rebuilt) short block that I bolted a rebuilt head to (I used a machine shop that I really trust) with new head bolts. Well, in the quest to save a little money, I used an off brand gasket set (one of those asian engine sites on the internet).......it was Chinese but, it looked like good quality stuff and now I need to replace the head gasket! I know, don't say it I have always used OEM head gaskets before and I should have this last time. I don't want to do this a third time so, I'm asking.......anybody recommend Felpro (only thing I'll use on my V8 rebuilds) or stick with the factory Japanese stuff.......Flame suit on, have at it! And yes I searched......just want some fresh opinions-------------Hans
Just a redneck trapped in a brown man's body
Oatmeal is offline   Reply With Quote Quick reply to this message
Old 11-12-2009, 06:09 PM   #2 (permalink)
Member # 144923
Send a message via Yahoo to Full Throttle ORC
I've never had a problem with felpro. Just fyi, you shouldn't buy chinese knock-offs for japanese engines.
Full Throttle
Northwest Ohio
Full Throttle ORC is offline   Reply With Quote Quick reply to this message
Old 11-12-2009, 06:27 PM   #3 (permalink)
Member # 14600
Originally Posted by Full Throttle ORC View Post
I've never had a problem with felpro......
Yeah, but would you rate them as better than the OEM stuff?
....... Just fyi, you shouldn't buy chinese knock-offs for japanese engines.
I, know (hanging my head in shame)------------Hans
Old 11-12-2009, 06:34 PM   #4 (permalink)
Member # 144923
I don't know about better than OEM. How can one put a rating on, "It works, or it doesn't". They don't seem to work any longer, or less than OEM. Also, make sure to follow proper torque specs when installing the head. You go out of order, and you can mess something up. There is even a removal order. The manufacturer specifies that improper removal can even cause warping of the head, in turn causing head gasket failure. The removal order is the same order as installation. Only, 1/4 turns at a time, in order, until all are loose.
Full Throttle
Northwest Ohio
Old 11-12-2009, 07:30 PM   #5 (permalink)
Member # 14600
A lot of guys on here have different opinions/experiences with Felpro vs OEM, just trying to gather additional data before doing it again
...... Also, make sure to follow proper torque specs when installing the head. You go out of order, and you can mess something up. There is even a removal order. The manufacturer specifies that improper removal can even cause warping of the head, in turn causing head gasket failure. The removal order is the same order as installation. Only, 1/4 turns at a time, in order, until all are loose.
I am very familiar with the procedure, having done several head gaskets/rebuilds. Just made an error in judgement when selecting head gasket brand. And actually, removal is the reverse sequence of the install ie. .......last bolt tightened = first bolt loosened Thanks for the input!----------Hans
Old 11-12-2009, 09:58 PM   #6 (permalink)
Member # 136617
I personally say stick with the factory hg. I have blown a felpro as well as 2 friends of mine, as soon as we made the swap to the factory gasket, we have not had a problem sence.
runnerboyy is offline   Reply With Quote Quick reply to this message
Old 11-13-2009, 04:45 AM   #7 (permalink)
KCaudill's Avatar
Member # 118530
Buy FelPro and keep me in a job!!
KCaudill is offline   Reply With Quote Quick reply to this message
Old 11-13-2009, 05:52 AM   #8 (permalink)
Kaptain's Avatar
Member # 31353
Send a message via AIM to Kaptain
Headgaskets are not the place to cut corners - go with the best which is OEM.
Rusted 93 X-cab on bald 37's
Kaptain is offline   Reply With Quote Quick reply to this message
Old 11-13-2009, 07:13 AM   #9 (permalink)
ssic off road shop's Avatar
Member # 105212
And what kinda discount do we get for keeping you in a job? except Pay Pal?
CalROCS 2011
ssic off road shop is offline   Reply With Quote Quick reply to this message
Old 11-13-2009, 08:49 AM   #10 (permalink)
Member # 85302
dont forget to check the torque after a few hundred miles...
(i had to chime in)
Will.The.Thrill is offline   Reply With Quote Quick reply to this message
Old 11-13-2009, 04:26 PM   #11 (permalink)
Member # 144923
I had a brainfart while typing it. Couldn't remember if it was same, or opposite. Got to that line, and went "duh!".
Fact is, alot of guys do cut corners on the head gaskets. Even when buying a felpro. Last I knew, they had several "grades" of gaskets. Such as OEM spec replacement, performance upgrade, long life, or however they list them. Too many people go with the "economy" version, and wonder why it fails. I run hundred's of thousands of mile on mine. As an example, I have people ask me how I make my brakes last while they change theirs 2x as much. I spend the extra $$ and get the higher performance ceramics, where they buy the economy grade bi-metals. There's a reason as to why it's cheaper.
Full Throttle
Northwest Ohio
Old 11-13-2009, 05:03 PM   #12 (permalink)
bigmudder's Avatar
Member # 82227
Send a message via MSN to bigmudder
I just blew a felpro one some are good some arent its all about prep bolts torque and such
86 yota/toy junk again /exo/ stackers with 4.7/ 40 iroks /turbo pane
bigmudder is offline   Reply With Quote Quick reply to this message
Old 11-13-2009, 05:08 PM   #13 (permalink)
Member # 14600
You're right and the stupid thing is I know better! I've have always used OEM before and have never had any problems. Saved a couple of bucks (and just a couple, mind you!) and gained a headache.......doh! Another thing I have noticed, rebuilt motors never last as long as the originals. I had my last motor rebuilt (the one I just replaced) by a very reputable machine shop (wasn't cheap!) and it barely made it to 100,000 miles. Oh, yeah I replaced the head gasket on that one at about 70,000 miles and it finally died when I lost the rings in one of the cylinders........sigh. Maybe it's time to build a stroker. I have that other motor sitting on the stand -----------Hans
Old 11-15-2009, 08:04 AM   #14 (permalink)
denver d's Avatar
Member # 16793
Don't forget to clean out the bolt holes with a thread chaser. Especially the 2nd and 4th on the exhaust side.
Toyota offers three different rod and main bearing sizes for stock rotating assemblies (stamped into the block on the oil pain gasket surface),where as aftermarket is either "stock" or under sized for a ground crank.
I think that is why the factory build always seems to last much longer.
denver d is offline   Reply With Quote Quick reply to this message
