22r with oil in the radiator - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-09-2009, 06:00 PM   #1 (permalink)
Newbie
HANNIBALTJ's Avatar
Member # 134944
ok guys heres a weired one..... timing chain out cut whole in the front cover fixed that but it also has oil in the radiator...... never seen this before, done alot of timing chains and welding the front covers but never seen oil in the radiator, any help?????????
HANNIBALTJ is offline   Reply With Quote Quick reply to this message
Old 12-09-2009, 06:03 PM   #2 (permalink)
Member # 16789
Blown head gasket? Is there water in the oil?
shipping and free returns
Wanted! Solid axle steering boxes from 1979-1985 toyota pick-ups and four runners. PM me for details.
Wanted! Power assist Rams and Valves from 75-77 Ford F-250's. PM me for details.
montezuma is offline   Reply With Quote Quick reply to this message
Old 12-09-2009, 06:06 PM   #3 (permalink)
Member # 87083
X2 on the above statment.
1992 Dodge W250, CTD 5.9/G360/205/60/80
1982PrairiePounder is offline   Reply With Quote Quick reply to this message
Old 12-09-2009, 06:07 PM   #4 (permalink)
Newbie
HANNIBALTJ's Avatar
Member # 134944
pulled the head also gasket good...well at least it looks good maybe warped head but gasket looks good dont see any cracks in the head either?????
Old 12-09-2009, 06:49 PM   #5 (permalink)
Member # 144923
Send a message via Yahoo to Full Throttle ORC
Haven't known many other ways for oil to get in the radiator. Always been a head gasket, or bad head. Depending on where the gasket blows, will determine the after effect. I've seen them blow between the cylinder and water passage (cause: over pressurizes water system, looks like gyser), between oil and water passages (sometimes water in oil, sometimes oil in water, sometimes both), and between the cylinder and oil passage (burns oil, gas in oil).
Full Throttle
Northwest Ohio
Full Throttle ORC is offline   Reply With Quote Quick reply to this message
Old 12-09-2009, 11:19 PM   #6 (permalink)
big ron's Avatar
Member # 71495
how did you get the head off with out destroying the head gasket
big ron is offline   Reply With Quote Quick reply to this message
Old 12-10-2009, 01:10 PM   #7 (permalink)
Member # 132275
Flush the systems see if it comes back it could be residual from the timing cover. Im guessing it ate a hole in the water pump side of the cover
I would rather smash my nuts with a rubber mallet than listen to you tell me how cool your jeep is!
12 ounce curls is offline   Reply With Quote Quick reply to this message
Old 12-10-2009, 01:50 PM   #8 (permalink)
Pat
Member # 120
you have to be kidding me
Try out a AppleSeed...
Pat is offline   Reply With Quote Quick reply to this message
Old 12-10-2009, 02:20 PM   #9 (permalink)
Member # 47016
x2..........
**TTC2013**
Spotter for SKOPs "Green Bastard"
Lil' lucifer is offline   Reply With Quote Quick reply to this message
Old 12-10-2009, 05:31 PM   #10 (permalink)
Newbie
HANNIBALTJ's Avatar
Member # 134944
gasket looks good ...as in no burned markes or blown areas.... not like im going to use it again
Old 12-10-2009, 05:34 PM   #11 (permalink)
Member # 144923
You sure? Or did you just give it a quick glance, and say "looks ok to me"
Full Throttle
Northwest Ohio
