Another home-brew front axle build - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-16-2010, 08:52 AM   #1 (permalink)
surftaco's Avatar
Member # 47670
Home-brew front axle and front 3-link build
After my stock pile of spare stock birfields ran out i decided it was time to order some longs. I figured i'd do it right the first time and order a set of custom length inners and build a housing to go with them.
The wms to wms will be 59.5", one inch wider then the rear
here is the list of materials i ordered from speedymetals.com
Product Quantity Length Sub Total:
1-1/4" {A} Rd Stressproof (or equivalent) Turned, Ground & Polished
1 72" $58.55
3-1/4" {A} Rd 6061-T6511 Aluminum, Extruded-12"
1 12" $46.77
2-3/4" OD {A} x 2.250" ID {B} x .250" Wall {C} DOM Steel Tube-48"
1 48" $60.55
3-1/4" OD {A} x 2.750" ID {B} x .250" Wall {C} DOM Steel Tube-48"
1 48" $78.83
Subtotal: $244.70
Shipping (UPS Ground): $49.18
Tax: $0.00
Total: $293.88
Then add $200 for machine work which means so far I've got just under $500 into the custom length housing. Still cheaper then all the other fabbed housings out there, maybe not as nice but i can make more for less
So here is what i am starting with
I used a pipe cutter to get the knuckle balls off the old housing
One more
I'll post some more pictures tonight
"Whoso Speaketh Of What Concerneth Him Not Shall Hear What Pleaseth Him Not."
Sir Richard Francis Burton
Build Thread -
surftaco is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 10:36 AM   #2 (permalink)
Member # 86280
Looks pretty good. I want to see more of it. What sort of plans do you have for trussing it, and such when done?
David D is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 10:39 AM   #3 (permalink)
Member # 85803
subscribed... cant wait for more progress.
looks good.
91 toyota on tons and 42's :homer:
Truggychev is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 11:30 AM   #4 (permalink)
Kaptain's Avatar
Member # 31353
Send a message via AIM to Kaptain
Very nice.. thanks for breaking down the materials used along with the cost.
Don't be afraid to post a lot of pics.
Rusted 93 X-cab on bald 37's
Kaptain is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 05:38 PM   #5 (permalink)
ssic off road shop's Avatar
Member # 105212
ummm the Ruff Stuff axle is under $500
CalROCS 2011
ssic off road shop is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 05:48 PM   #6 (permalink)
Ryan31783's Avatar
Member # 25835
Send a message via AIM to Ryan31783
I hate to say it, but RuffStuff has this housing for $480+shipping, you just need to rob the knuckle balls off your housing, or wait for them to offer balls.
That said, looks like yours will be built right. Keep up the good work!
edit: Got a phone call in the middle of posting, SSIC got to it before me
Mild 85 Toyota pickup (RUF & Chebbies) Sold
2009 RZR with a sportbike motor swap
Ryan31783 is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 05:58 PM   #7 (permalink)
Member # 54522
why not just use a 9in?
86 4runner 7MGE bobed, exo, SAS on 38s, 5.29, fully locked with duals/4.7 and 30spl longs
dopeassjackson is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 06:45 PM   #8 (permalink)
surftaco's Avatar
Member # 47670
I thought about the ruffstuff axle, Im my opinion you still need the alignment bar to weld the knuckle balls on straight. I really wanted to use their HD knuckle balls though, too bad they aren't out yet.
Plus I may sell this axle down the road and build a set of matching axles 63" wms to wms
I already have geared and locked toyota 3rds other wise i would have went with the 9" or landcruiser 9.5". I also have a bunch of toyota housings to cut up and steal parts off of.
Build Thread -
Old 01-16-2010, 07:18 PM   #9 (permalink)
surftaco's Avatar
Member # 47670
I didn't get a whole lot done today, Mostly just alot of staring, thinking, and measuring
the tubes are in
The new tube was originally 2.75" OD but i had it turned down just enough to fit inside the 3.25" x .250" tube. The inside of the factory housing is still just a little bit smaller, so ground down the factory welds and split the seams a little.
I plan to gusset the tubes inside the housing sort of how the diamonds are.
I havn't decided if i want to sleeve the whole long side with the 3.25" tube yet (way overkill) or just enough to get the knuckle balls on.
Build Thread -
Old 01-16-2010, 08:56 PM   #10 (permalink)
Member # 121798
Dope.
[CENTER][COLOR="Red"]1992 4Runner
[SIZE="1"]'99 3.4 and 4 tires. They're black :smokin:[/SIZE]
1986 4Runner
[SIZE="1"]'Axled and locked daily on 35's...mall crawler :flipoff2:[/SIZE][/COLOR]
[COLOR="Yellow"]IBEW Local 48[/COLOR][/CENTER]
A New High is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 09:03 PM   #11 (permalink)
tuen!! tuen!!
chickamaugajay's Avatar
Member # 110144
Nice job Sir.
SUMBITCHLLDIG
chickamaugajay is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 10:49 PM   #12 (permalink)
Member # 81334
Awesome, shipping to 95667?
"Chrome won't get you Home"
85 Yota Sittin on 38.5 Sx's and a whole bunch of du-dads...
Monster Yota is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 10:58 PM   #13 (permalink)
Member # 67357
Waiting to see more.
KyTrash is offline   Reply With Quote Quick reply to this message
Old 01-17-2010, 03:25 PM   #14 (permalink)
surftaco's Avatar
Member # 47670
I forgot my camera today but i got some cell phone pics, better then nothing i guess.
I started making the internal gussets
and i got the outer sleeves cut. the length will still need some fine tuning, I may end up trimming some more off
I'm going to take the outer sleeves back to the machine shop and have the knuckle balls pressed in. Then i'll make some final adjustments to the length and set the caster. After that it should be time to start welding everything up.
Build Thread -
Old 01-17-2010, 03:27 PM   #15 (permalink)
surftaco's Avatar
Member # 47670
I think i might hole-saw some material out of the sleeve on the long side to try and save a little weight
Build Thread -
Old 01-22-2010, 06:46 PM   #16 (permalink)
surftaco's Avatar
Member # 47670
Made a little progress if anyone cares
Build Thread -
Old 01-22-2010, 06:53 PM   #17 (permalink)
Member # 101054
Why buy something that you can build yourself and then have the satisfaction of having done it yourself? Buying "pre-fabbed" parts is for people that cant do it themselves
I am not better then anyone But I am just as good as everyone.
dmsFab is offline   Reply With Quote Quick reply to this message
Old 01-22-2010, 06:59 PM   #18 (permalink)
Lets Ride
ricsrx's Avatar
Member # 131553
Nice work I cant wait to get going on a front axle, SUBSCRIBED
My build
bumper
locks
ricsrx is offline   Reply With Quote Quick reply to this message
Old 01-22-2010, 07:00 PM   #19 (permalink)
JediJesus's Avatar
Member # 132056
Very cool man, looks great. What gears are you using, and what diff/locker?
Are you going to do the same thing or something similar to that other axle in the last pic?
Oh, and shipping to 97219
JediJesus is offline   Reply With Quote Quick reply to this message
Old 01-22-2010, 07:10 PM   #20 (permalink)
Member # 21320
Nice work
TDI swapped lwb Samurai
BCzuk is offline   Reply With Quote Quick reply to this message
Old 01-22-2010, 08:38 PM   #21 (permalink)
surftaco's Avatar
Member # 47670
I run 5.29s with a lockright out back an aussi locker up front. I have a welded carrier I plan on replacing the lockright with eventually
The other housing was just for measurements
Build Thread -
Old 01-22-2010, 09:07 PM   #22 (permalink)
Member # 67357
LOOKING GOOD!! Carry on now! When can I mail you, mine? Practice makes perfect!
Old 01-22-2010, 09:36 PM   #23 (permalink)
Member # 85972
awesome thread.
I'm not on Pirate much anymore, but you can find me on here-
And yes I still have lots of build parts for sale! New website coming soon!
billybob13 is offline   Reply With Quote Quick reply to this message
Old 01-22-2010, 09:56 PM   #24 (permalink)
Member # 37728
Very cool work... I myself will be getting a ruffstuff housing if I can ever get back on my feet b/c I can't do this kinda shit. Kudos to those that can.
I got nothing...
wslytoy82 is offline   Reply With Quote Quick reply to this message
Old 01-22-2010, 11:18 PM   #25 (permalink)
Member # 119605
Very nice work
Looks like you have a great start on one burly-ass housing.
85ToyotaTom is offline   Reply With Quote Quick reply to this message
