#651 (permalink) |
O-ring Technologist
Member # 62564
Took the rig for a spin around the yard. Other than a few leaks, everything else seems to be working fine. I adjusted the throttle stops and cleaned the dashpot and the idle returns to normal now. Now to fix the leaking fittings, and finish the wiring.
#652 (permalink) |
Member # 115887
Just lost a few hours of my life reading this thread. The progression is ridiculous, as is your fab work.
But Dude, you've got to get a better camera!!
God hates a coward. Nolite esse canis praecisae Last edited by crashhawk; 06-08-2012 at 05:56 PM. |
#654 (permalink) |
O-ring Technologist
Member # 62564
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Took the rig out to Bald mountain for a shake down run. I ran a buch of dirt roads, and then hit the trail. Couldn't have been a better run. No unexpected issues and the truck worked well even with 15psi in the tires. The trans shifter wasn't working; I think I wired it wrong somehow but I knew that when I pulled it out of the shop last night. I still have a bunch of finishing touches to add, but atleast it's wheelable again
#658 (permalink) |
O-ring Technologist
Member # 62564
Hung like a tuna can
![]() Thanks. I'll be at moonlight fri-sun. Feel free to come by andnsay hi if you see me. Probably gonna do the day run, and then watch the action on the night run. Last edited by friggnxj; 06-17-2012 at 11:07 PM. |
#659 (permalink) |
O-ring Technologist
Member # 62564
Got some stuff done. I fixed the shifter issue. Turns out I mixed up the imput wiring on the relays. Two minutes later, I had the thing shifting like "normal".
Threw on some rock lights: ![]() ![]() Same spot as last time: on the bellhousing inspection cover, and below the rear ouput shaft. Then got to work on the rear floor section: ![]() ![]() I also got the seat mounted. |
#660 (permalink) |
Member # 107858
What are your initial impressions of the V8? im swapping in a 1uz in my FJ40 and am getting excited to get her running. just wondering what you thought of it so far. Ive got the older motor but i am running megasquirt and i ditched the dual dizzys for edis.
77 FJ40-FZJ43 coming... 01 IS300-fun |
#661 (permalink) |
O-ring Technologist
Member # 62564
My inital impression is that I now have more than enough power to break shit. It is nice having all that power so that I can really scoot along dirt roads, and I can't wait to take it out to JV and run it wide open. Crawling on the other hand, it is the automatic trans that makes the biggest difference. I noticed the motor is kinda dead below 2000 rpm, but is a rocket above. I haven't done anything as far a performance mods to the motor. All I have done is deleted the emissions crap and have opened up the exhaust. I did notice that with the front sump, that after about a minute on a steep incline the oil pressure dropped off to around 10psi (idles around 25psi at operating temp). I think down the road, I might fab up a rear sump pan or run an accumulator.
#662 (permalink) | |
Member # 187697
(it's rear sump) |
#663 (permalink) |
O-ring Technologist
Member # 62564
Isn't it more of a mid sump? Plus, the width of the pan is what is killing me. My links come really close to the pan, moving the stock pan rearward is not really an option.
#664 (permalink) | |
Member # 187697
shouldn't be a problem to narrow it up... And if you move it back don't the links get "wider"? |
#665 (permalink) |
O-ring Technologist
Member # 62564
The links would be "wider" but at that distance back, the links would be at the same height as the widest part of the oil pan at ride height. I would think that any sort of lateral movement in the links would cause contact with the pan if using the SC pan. Right now the links are much higher than the pan, and only pass above the pan at full bump. I just wonder if the pan is a structural part of this motor?
#666 (permalink) | |
Member # 187697
Not sure if its structural. I doubt though. I can snap some pics of the sc setup if you want. I've gotta get my shit mocked up so I can figure out links. Out of curiosity how far back is your motor? Maybe a good gauge is how many cylinder are past where the oe firewall would be? |
#667 (permalink) | |
O-ring Technologist
Member # 62564
I'll try to get some measurements tomorrow. I know the motor is back a bit. It will probably be a number from the front of the crank to an imaginary line that runs across the front edge of the forward body mounts. |
#668 (permalink) |
Member # 136778
dude its a tight fit around the oil pan no matter what frame and axle!
i mocked up my front 4 link with a 22r.. then plans changed.. now my 112 wheel base is around 117 and my 4 link might turn into 60 inch long radius arms and a panhard it sounds mean i cant wait to get mine done.. i think i will blow shit up fast! keep me posted us posted on your oil pan mods i have the sc? the one with the rear sump.. and it still is lame.. dry sump cost some $$ but i might end up going that route
facebook.com/pages/Zukijames/152521404841727 toyotav8.com hellfirefabworks.com |
#669 (permalink) |
Member # 136778
just some stupid questions.. and i could probably find them if i read your whole thread but its 6:06 am and i havent gone to bed and have been reading trying to figure out my swap stuff all night!
1: do you think the gutless under 2000rpm has something to do with the auto trans? 2: what case you running? 3: how fast do you think i will blow up dual yota cases? 4: whats your frame/belly height 5: what is the height of top bolts on bell housing .. or bottom of oil pan whatever is easier for you to measure? 6: If you know what you know now would you still choose to use a 1uz? thanks sorry im being annoying sleep deprivation is not good.. sun is up now i can get off the computer and go work on front suspension .. 7: from " its the auto that really makes the difference" i take it your glad you went the auto route?
#670 (permalink) | ||
O-ring Technologist
Member # 62564
#672 (permalink) |
Member # 136778
thanks for the info i just pm'd you asking if you had a build ha i was pretty tired when i was reading this this morning!
if i put my frame at 21 inches my pinion is on my oil pan! messed around with it a little today hopefully mine turns out half as nice as yours!!
#673 (permalink) | ||
O-ring Technologist
Member # 62564
No worries though. My drivetrain is raised a little so I could do the flat belly. Also to Dana axles have their diff more outboard than do the yotas. Would a two piece driveshaft help?
#674 (permalink) |
Member # 136778
i dont think a 2 piece would help thats what i was thinking before but now im not sure..
my yotas are 63 wms to wms but a little more width or offset would be enough to not hit .. i wish i could tig and i'd take the oil pan off and see what it would take to modify it a little. on the pass side the oil pan comes strait down from where it bolts on . if i could just slope it from the pan gasket to bottom of pan i would be fine anyways sorry for the hijack awesome rig !
