4 Runner won't idle sometimes - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-20-2010, 04:20 PM   #1 (permalink)
desertoy's Avatar
Member # 292
My wife's 1987 4Runner has a problem. After driving it approx. 10 miles, it doesn't want to idle. The rest of the time it runs and idles just fine. Only after you drive it 15 minutes or so. Once it starts acting up, if you stop and just keep it running for a minute or 2, the problem goes away. Drive it a few miles, the problem comes back.
Here's what I have done:
Changed plugs and wires
Changed fuel filter
Checked fuel pressure (between 32-42psi even when it won't idle)
Changed temp sender that didn't ohm out (the one next to the cold start sensor)
It doesn't have any fault codes, it runs fine other than intermitant ideling problem.
Any suggestions????
John James
Team Marlin Crawler
X-Chassis #12
6 time KOH finisher
2008/2009 W.E. Rock West Coast Series Champion
2008 Pro Rock Champion
Just "HAMMER" it!!
My Buildup
desertoy is offline   Reply With Quote Quick reply to this message
Old 02-20-2010, 04:50 PM   #2 (permalink)
Member # 127998
02sensor or tps
dirty530 is offline   Reply With Quote Quick reply to this message
Old 02-21-2010, 03:51 PM   #3 (permalink)
desertoy's Avatar
Member # 292
I would think either one of these would throw a fault code.
John James
Team Marlin Crawler
X-Chassis #12
6 time KOH finisher
Just "HAMMER" it!!
My Buildup
Old 02-21-2010, 04:36 PM   #4 (permalink)
Member # 49211
tps
negative ghostrider. never had any o2 sensor problems, but my tps crapped out and never threw a code. ran about like yours but no codes. good luck.
oldskoolss is offline   Reply With Quote Quick reply to this message
Old 02-21-2010, 04:53 PM   #5 (permalink)
sucker's Avatar
Member # 147955
Try swaping the ecu? See what it does?
sucker is offline   Reply With Quote Quick reply to this message
Old 02-23-2010, 01:59 PM   #6 (permalink)
Member # 88143
i had a similar problem because my throttle had accumulated too much carbon/gunk. try a $5 can of throttle body/carb cleaner. remove air intake from throttle body, spray inside and move accellerator to open/close and work out the gunk, also spray spring outside until it moves freely.
HappyCamper is offline   Reply With Quote Quick reply to this message
Old 02-23-2010, 09:19 PM   #7 (permalink)
Cranky Moderator
steveh's Avatar
Member # 2026
Send a message via AIM to steveh
Check the TPS. Most likely culprit. Roger Brown's Write up is the best guide. They don't always toss a code when it's an intermittent issue.
85 Toy Xtracab
"I DON'T want to understand !!"
"Wow this is unbelievable"
steveh is offline   Reply With Quote Quick reply to this message
