Member # 158363
86 pick up 2x4 to 4x4 research
hi all just to let you know up front i am doing researcher right now for my truck. i have an 86 toyota pick up two wheel drive with a 22re and a 5 speed manual trans. i was talking to a friend at work about what i wanted to do and he offered me a set of scout d44's front and rear with disk brakes all around and the spring towers for the front for $100 bucks. my question is not that this is a good deal just what are your thoughts on my plan to use these axles for my conversion. i will still need a t-case and drive shafts but i am not too worried about that right now. the plan for the truck is light wheeling running 35's at the largest
Member # 16789
/forum/toyota-truck-4runner/402767-50-two-wheel-drive-four-wheel-drive-conversion.html
This is the link to my 86 2wd-4wd conversion. You will need to deal with the fact that you have dana 44's (IE: spring perch width, if the knuckles need to be rotated, pinion angle, etc.) Other than that, you need all the stuff you would need for a normal IFS conversion plus the (off the top of my head): -Transfercase -Transmission -steering box (using the 2wd box is more involved) -two driveshafts -custom crossmember -Exhaust down pipe from a 4x4 or early 2wd. -4wd fenders if need be I'm probably forgetting something, but it's all in my thread (pictures are no more so use your imagination). The 2wd frames are nice, and more resemble the solid axle stuff than the IFS frames do. Good luck.
The Parts Pimp. Wanted! Solid axle steering boxes from 1979-1985 toyota pick-ups and four runners. PM me for details. Wanted! Power assist Rams and Valves from 75-77 Ford F-250's. PM me for details. $78 for Toyota front knuckle rebuild kits DELIVERED!! PM me for details. Last edited by montezuma; 04-14-2010 at 03:45 PM. |
Member # 85302
sounds like he's trying to unload a can of worms on you, IIRC those axles are hard to get parts for and are different that other dana 44s.
if you want a solid axle go with a toyota axle, $0.02 |
Member # 158363
the guy has several scouts that he bought to build one and he offered them to me if i wanted them for that price.
also what is different on the scout 44's compared to the others that would make parts harder to find? |
Member # 85302
i really don't know for sure, i just heard that from some guy with a scout i met at the archery range, I've never researched it...that's probably something you should do if you plan on using scout axles
#9 (permalink) | |
I See You
Member # 138976
The Scout stuff will also be sprung under, if stock, so keep that in mind too. |
Member # 105761
Just did this with a 1st gen 2wd. It's an easy swap the Ida is easy to cut off reall quick and simple. The shackles are a pain to cut into the frame cause the tg jigs wouldn't work. Your going to need a tranny as well as a transfer case. Your better off finding a set of toy axles though just my two cents. If you have any questions shoot me a pm or check out my build thread.
