instead of hysteer arms or the double arm for normal xover, you take the draglink and connect it to the tierod, ive seen it with coils but not with leafs, but aslong as you mounted it so that on full lock to the right it didnt contact the leaf it would be okay, but the the draglink would be kinda short. so would this werk? or if someone has done it got pics??
Attaching the drag link to the tie rod is an option - if you wanna go low $$$.
You will need an "s" shaped draglink - that makes it weaker.
The stock tie rod is NOT up to the task either - so plan on a serious upgrade there.
Bumpsteer will be an issue as well.
I think the idea is to get the tie rod and drag link as close to parallel as possible. The greater the angle between the two, the worse the bump-steer. I have my drag link connected to the tie rod, but both are above the springs. There would also be an issue of exactly how to connect the drag link to the center of the tie rod. Someone out there probably has a solution, hopefully a few others will have some input.
well my waggies are pretty flat so i think i could get the two fairly parralel, i was thinkin a little bracket in the tierod and i could even raise it a couple of inches to make the angle less, or would there be too much sheer force on raised type bracket??
Jack Alford went through this whole thought process back
in 1997 before he did his crossover and was looking at
various ways of running the links. With the way the Toy leaves
mount you have to go s-link as David mentioned....
not good, or pull the attach point further to the driver side
of the passenger leaf. This makes the draglink angle way too
steep for the height of lift we typically run.
Agree with Jay - Jack did a TON of research and trial/error on this (I still have his original draglink w/ the angle iron welded to it for strength). It's not worth trying to reinvent the wheel again to save some $$.
Reminds me... how many people really remember the fact that Jack was (the FIRST?) guy to document this swap on-line and make it popular??? Should have patented the idea, Jack!
lol ... did that tie rod ever bend when used as a draglink. Jay was there he saw it ... what was I thinking that the puny toyota tie rod was up to that task :nuke: ... live and learn
Ha ha...one of the evils of draglink angle. Curled the thin wall
tube like a pretzel. Luckily one of the guys on Golden Spike
had a welder and Jack had that angle iron. Pretty funny that
it's still on there......
Cool....I remember those old pics. Long time ago!
Jay
