i new you would look if i was going to look for a used ram what would i need to do hydro ass.?[ how long what size all the specs] i think i have a line on some rams but don't know what to look for thanx
you're sure, positive? wow i'd have NO turning radius with a 6, since i use ALL of the 8in stroke i have on mine, so if you could jack, please tell me how a 6 would be perfect??morpheus said:1.5" x 6"
- jack
A braver man than I!Originally posted by morpheus
Re: hydro ass. ram ??
1.5" x 6"
If you have access to infinitely adjustable ram travel lengths, this method works wonderfully. Most of the time, you have to compromise based on having enough ram to steer far enough.DRM said:So in summary, the CORRECT answer is that you need to mount your tie rod, determing where you want the ram mounted, mark both locations, move the steering through it's range of motion, and measure that net change in distance. Subtract a wee bit (so the ram limits your steering, not so the ram pushes against the steering stops) and you have the ram stroke you need... right?
yep ... by looking at the dude's sig I could tell he had a toy axleDSI said:
that is a good jod for you.just don't role them:flipoff2: you mite wont to cage them befor you move themBooger Weldz said:mine is 1.5x8, i got it from scott, works with the stock pump great.........check it out at the cleanup--come by, i owe you a :beer:!:flipoff2: ill be movin shitters at spider...
:laughing::laughing::laughing::laughing::laughing:toy 4 rox said:just don't role them:flipoff2: you might want to cage them before you move them
I have Marlin's High steer on mine too and I measured just over 5" of travel. I'd say measure before getting the ram just to be sure.toy 4 rox said:yes it is a 85 runner toy axel with marlin high steer.. so it looks like 1 1/2 X 8" is what i need.. will the stock pump work?
