I talked to a guy some time back about an orbital valve and ram he got for 275 and he gave me the number but I have lost it. Anyone else get their ram for cheap and where and number is appreciated.
erik
Go to the bulleting board on www.tennessee4x4.com and look in the for sale section for a post by a guy name Hostelton Offroad or something like that. The post is probably a month old now. He had real good deals on Charlynn valves w/ rams. HTH
Or search under a post on PBB by me for full hydro. I have 2 or 3 of them and one of them has the number for Alvin. I got my setup from him for 278 shipped.
That included the used valve, new ram and ounting blocks. Great deal, got it in under a week. My brother got the same.
Dont forget you're gonna need a 10in. ram for those rockwells. he dosent know a whole lot about ram length unless you're talkin Dana's. BTW, get the 2.5 " too.
Another recommendation for Alvin Hoselton. He is a stand up guy. Station on this BB is a really guy for hydro stuff also. If you get an internal spline orbital, I found a Char-Lynn part number for a 12 spline piece that will weld in to a .750 ID tubing and just plug into the orbital valve. It was Eaton part number 8063 and was less than $15. Much neater than welding to the tower. I am using a Borgeson 3/4 bore ujoint with a 3/4 DD on the other end toconnect it to my stock steering column. I should have it finished up tomorrow.
Thanks tyty I think it was you I was talking to last time. I'm gunna run an 8 inch ram because I plan on running high steer and running a shorter arm on each side. 10 rams are aweful long and an 8 inch will work fine with the shorter arms. Thanks again
erik
Man I try calling that guy and his phone just rings and rings! Anyone else had this problem? Where does he live and I can call information for his number. Does he work elsewhere so he is only at that number once in a while? thanks
erik
He lives in Tullahoma TN. He also works at the Autozone in Tullhoma.
