22RE idle adjusting - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-19-2010, 06:07 AM   #1 (permalink)
Member # 140620
22RE idle adjusting
Have put a 22re in my 85 hilux.
Having trouble with ruff idling, idles low and dies. Tryed to adjust but im not sure if im doing it right.
Im adjusting on the screw (hexagon with nut) located just about in the middle of this pic :
Isnt it the right one ?
Have changed fuelfilter, so that shouldn't be the problem.
JimRS is offline   Reply With Quote Quick reply to this message
Old 06-19-2010, 06:17 AM   #2 (permalink)
nice roach.
jhama78's Avatar
Member # 3377
Send a message via AIM to jhama78
the flat head screw on the throttle body adjusts the idle as well...
-j-rOd
wear life like a loose garment
84 Toy Farm Beater
85 Toy SR5 xcab DD
86 GMC K1500 SWB
88 4Runner Fambly Beach Ride
11 Tundra Double Cab Rock Warrior
jhama78 is offline   Reply With Quote Quick reply to this message
Old 06-19-2010, 09:04 AM   #3 (permalink)
Member # 140620
Originally Posted by elephant butte View Post
and also means you put the cable stop back where it was. if it works you are doing fine if it doesn't you got another problem. like tps adjustment.
Cable stop, is that the screw ive been adjusting ? Underneath the screw i adjusted it hits somekind of vacum thing, what is that thing ?
Old 06-19-2010, 09:21 AM   #4 (permalink)
mmml4's Avatar
Member # 100195
That thing is called a dashpot.
mmml4 is offline   Reply With Quote Quick reply to this message
Old 06-19-2010, 12:58 PM   #5 (permalink)
Member # 134561
The truck should idle high when cold then settle to about 725 or so when warmed up... I'm guessing that's not happening, right?
So, warm the engine up and set the timing and idle.
Then fix the problem you have with IAV/AAV under the throttle body and then re-set the timing / idle 'cause it won't be right after fixing the problem.
abecedarian is offline   Reply With Quote Quick reply to this message
Old 06-19-2010, 02:04 PM   #6 (permalink)
Member # 140620
You are right, it doesn't idle high when cold anymore. Don't understand why i have to adjust the timing too, i haven't touched it. What is IAV/AAV ?
Im hopless with search, would have done better if you guys typed in norwegian
Old 06-19-2010, 08:29 PM   #7 (permalink)
Member # 134561
IAV/AAV is idle air valve / auxillary air valve. It is a temperature controlled valve that lets air around the throttle when cold and closes when warmed up. On early models, it's called IAV and is mounted below the throttle body and on later models it's called AAV and part of the throttle body.
Old 06-20-2010, 02:33 AM   #8 (permalink)
Member # 140620
Thanks alot Great write-up, elephant.
Mine is a 88, don't know if i got IAV or AAV, but i guess it doesn't matter.
