#152 (permalink) |
Member # 110135
I gotta tub my firewall first, then break in the R&P's. I also need to put a hitch on the back of my tow rig.
There are 2 kinds of fools: weather predictors and their believers |
#153 (permalink) |
Member # 110135
After flexing the suspension for the first time, I noticed several things that needed changing. First, and foremost, on full stuff, the front tires would contact the body seam at the rear of the fenderwell. I did a search and found a lot of info. Here are the results of that:
First I cut out the offending sheet metal. I used three different tools: an air body saw, a sawzall, and a die grinder with a cutoff wheel. You have to be real careful when using the sawzall- it's aggressive.
#155 (permalink) |
Member # 110135
Then I made a template and transferred it to a piece of 16 ga steel. I cut it out with a plasma torch and skip welded it into position.
#157 (permalink) |
Member # 110135
I then reflexed the suspension again until I was at full compression, indicated by one wheel lifting. Nothing made contact. The rear tire looks really close, but there is some daylight there.
#164 (permalink) |
www.12voltguy.com
Member # 40
looking at the pics, he didn't trim off 8"s, the lip is still there on built in flare, bet he only trimmed 2" out, so he could not leave 8"s,lol
12voltguy info@12voltguy.com--davezoffroadperformance.com # 530.532.4529![]() TTC 2010 1989 BRONCO -Awesome web development for your business. www.mudnworks.com mud@mudnworks.comPat's W I D E TOYOTA Front Axle --07 KTM 450XC----with "stuff" |
#165 (permalink) |
___________
Member # 3495
When those springs 'break in', it'll stuff more.... and probably rub the tubbed firewall a little bit. Which is cool... 'cause it end up being just right!
Update us! This build keeps me going!
'85 4runner, locked, lifted, TSL's, 4.7:1 twin stick tcase... |
#166 (permalink) | |
shoes optional
Member # 142117
yep your right. i looked back and its probably no more than 2inches cut out. well dang thats a lot a of room left and im sure the springs wont break in that much, on my rig i was able to only cut the front and back and still have the factory look on the middle/top of my fender maybe if i ditch the 39.5's and get 42's i could get a reason to cut more Last edited by drewp; 09-22-2010 at 10:19 PM. |
#167 (permalink) |
Member # 110135
The only new update is I added a set of rock sliders (pre-fabbed
). I've been doing some driving and getting used to the rig. The one thing I can say is that since installing the "bomb proof" motor mounts, there is alot more vibration. But, I expected that and I can live with it. Warpig- any word on your front axle situation?
#168 (permalink) |
Member # 160119
got the locker on monday, gave it to Lloyd on wednseday, supposed to pick up the new third on Friday, hope to install on saturday or sunday and thus be able to break in the new set up in time for the mudd boggs next weekend. i sure hope that you are planning on going to the boggs owl
TTC 2011 Competitor |
#171 (permalink) |
Member # 160119
thats what i have been told by several people so i am going with it. that is next weekend, i will be ready as will spinney and sounds like Gray and his runner will be there, should be a good time as usual. im going to go up fro friday and saturday, you gonna make it or what?
#173 (permalink) |
Member # 160119
yes i will be camping on friday night. got my rig assembled today, i am good to go and ready to rock. cant wait to do some wheeling together...seeing as how we have the same tires and such, should be a pretty fun match up! post up some pics of the sliders owl
