Cold start injector switch?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-18-2010, 09:15 PM   #1 (permalink)
Member # 160922
On my 86 Toyota truck 4x4 2.4 EFI the OEM number for the cold start injector switch is 89462-30011,but that has a square female end and mine is round cornered.Does anyone know the OEM number for this part?The truck originally had a turbo engine and now has a new 22RE.Did the turbo have a different switch number?
mldave is offline   Reply With Quote Quick reply to this message
Old 08-18-2010, 09:36 PM   #2 (permalink)
Member # 111797
most likely it did. am guessing here though. your best bet is to call a toyota dealer.
Rotten Destruction
ToxicToy is offline   Reply With Quote Quick reply to this message
Old 08-19-2010, 10:52 AM   #3 (permalink)
Member # 33685
Just manually control it.
The Cold Start Injector is ground switched, Run a toggle switch in the cab connected to ground to the Cold start injector, When you walk outside and your G/F's nipples are perky, flick the switch, and the Cold start injector will run.
**** The good thing about the Cold Start Injector is it only runs while the starter is engaged, So there is no harm in leaving it in the on postion
The Time Switch and sensor are BIG bucks from Toyota. I've been running the manually switch for years no problem
MudRunner
4Hummer is offline   Reply With Quote Quick reply to this message
Old 08-19-2010, 12:39 PM   #4 (permalink)
Member # 162176
different years used different plug ends, its still the same injector tho, take a knife and whittle it down to fit and it will work just fine.
87 runner,87 standard,89 standard,94 yota4x4, 01 ford trac4x4, and a glass of wine!
elephant butte is offline   Reply With Quote Quick reply to this message
Old 08-19-2010, 08:06 PM   #5 (permalink)
Member # 160922
SO ALL THE COLD START INJECTOR TIME SWITCHES ARE BASICALLY THE SAME,EXCEPT FOR THE SHAPE.Correct?
Old 08-20-2010, 05:53 AM   #6 (permalink)
Member # 162176
pretty much, the design of the plugs you will find is that no other plug in the harnes will fit anything else, thats why its easy to do yotas, but between years they made the plugs for that year to the next different so people wouldn't use electric parts off other yotas, their way of making money i suppose. i have done it a few times for various things, even knock sensor
Old 11-16-2010, 07:15 AM   #7 (permalink)
Member # 160922
Since having the CSI switch bypassed it improved the starting to 2-3 cranks before starting.Then I changed the way I started it by turning the key to the on position for a second or two,then cranked the starter and flipped the bypass toggle switch..been starting first time ever since.
Old 11-16-2010, 05:14 PM   #8 (permalink)
jeaton's Avatar
Member # 26098
Send a message via Yahoo to jeaton
I am having this problem right now on my dads 86. Where do i find the switch that i want to ground?
thanks
jeaton is offline   Reply With Quote Quick reply to this message
Old 11-16-2010, 06:58 PM   #9 (permalink)
Member # 160922
http://www.yotatech.com/f16/22re-col...-bypass-68706/ the CSI time switch is located under the t-stat housing..the bigger one on the left when facing the engine.The one on the right is the thermo temp sensor I believe.
