My 85 truck won't start, or even turn on the headlights...
Here is what it does... You turn on the key everything appears fine, if you do anything that requires load on the battery, like turning on the lights or trying to start the truck, all you can hear is a bunch of relays clicking....
Here is what I have eliminated so far...
It is not the battery, tried 2, both fully charged, not the connections at the battery terminals, not the head relay in the fuse box in the engine compartment, tried another one, there was also another relay in the drivers kick panel, that was clicking, changed it with another one, still same.... Checked all fuses, fuseable links, have 12v at body, and engine....
The next thing I was going to try was the ground strap from the battery to the body, Am I on the right track? Is there another relay I should look at?
