Anglo Waste
Member # 72949
Cold starting ?'s/ starter relay bypassed
86 runner, 22re, 311k when i bought it last January. 328k now.
1. The PO had bypassed the ignition switch and installed a push button starter switch to start the truck. I had reverted back to the stock starting method soon after I bought it, only to switch it back 2 days later because it stopped working (probably why he switched it in the first place) Been that way ever since. ![]() I checked the stock ignition wire at the starter with either with a test light or a volt meter (too long ago to remember) and when in the start position it showed power to it, but wouldnt start. Hooked it back up to the push button and started right up. Didn't fuck with it again bc I was late for work and its been working since. I didn't think it would be the relay since it's showing power down at the starter. 2. It's finally getting cold here in TX and it dosen't like to start below say 50°F, and it takes a good 3-4 cranks (on a good day) to get the bitch started. And nobody wants to help me diagnose if the CSI switch is clicking on or not at 6am (I dont think it is) From what i read here and the attached yotatech link I think I solved my own problem that if i figure out why its not starting with the stock wiring the CSI should begin working? Gonna tear into it tomorrow, but just need to know I'm on the right track. It's Tuesday, dollar beer night, so don't have time to read 900 "my truck won't start" threads (And I'd rather be lookin at all the hot poontang at the bar than Pirate on my phone)
86 4runner 22re (beater), stock '76 FJ-40, 83 7mgte pickup Last edited by speedemon55; 12-14-2010 at 07:45 PM. |
Wicked Raciest !
Member # 30
The problem is your CSI is not getting turned on. The only way it will get turned on is if you turn the key all the way to where it used to engage the starter.I found this out after about four years of having a hard starting on cold starts. I found this out after troubleshooting the whole system to find everything checked out perfect and on a 3.0 it is a bitch.
Here is my routine; Hold the key all the way clockwise and count to four. Release key to run position. Press button and it should start right up.
David & Theresa, Roseville, CA, Remember: Amateurs ... Built the ark. Professionals ... Built the Titanic http://www.davezoffroadperformance.com/ http://www.marlincrawler.com/ http://www.12voltguy.com/ Last edited by OOP'S; 12-14-2010 at 08:31 PM. |
Anglo Waste
Member # 72949
I'll give that a try in the mornin. It's supposed to be 49° in the am. If that works I can get to all the other little crap I need to fix and been putting off, like the heater. I still would like to "fix" the problem, but if that gets me by a little longer that'll work.
86 4runner 22re (beater), stock '76 FJ-40, 83 7mgte pickup Last edited by speedemon55; 12-14-2010 at 08:55 PM. |
#5 (permalink) | |
Wicked Raciest !
Member # 30
David & Theresa, Roseville, CA, Remember: Amateurs ... Built the ark. Professionals ... Built the Titanic http://www.davezoffroadperformance.com/ http://www.marlincrawler.com/ http://www.12voltguy.com/ |
#7 (permalink) | |
Member # 33685
The Cold start injector is ground switched. And is controlled by the CSI Time Switch (expensive little bugger) The CSI only sprays when the Starter is engaged Run a wire from the Cold Start injector (Ground side) to a toggle switch in the Cab, connect the other end to a good ground. When you go outside and your cock turtle heads you know you need to enable the CSI. Leaving the switch in the on potion will not harm your RIG what so ever, as I stated it only spays when the Starter is engaged. Only problem is on hot days with the CSI on you kinda flood the engine for a second (As it doesn't need the extra fuel) and it stumbles for a minute as it tries to recover from the extra un-needed fuel. I live in Canada (The Great white north eh!) And never have a problem starting my Toy in the middle of winter since bypassing the CSI Time Switch.
MudRunner Last edited by 4Hummer; 12-20-2010 at 11:43 AM. |
#8 (permalink) | ||
Wicked Raciest !
Member # 30
Just another switch to remember to turn on/off (I am old and a child of the 60's), my way works perfect for me.
my dads 88 is having this problme...where is the wire on the motor that i need to ground? its jus a lil farm truck but he gets pissed that it takes 10x for it to start. do you have a pic of said wire?
KOH 4509 82 Toyota Thanks to my sponsors www.pascoautowrecking.com www.4wheelunderground.com www.prpseats.com www.racelinewheels.com www.falkentire.com www.f-o-a.com www.longfieldsuperaxles.com www.ruffstuffspecialties.com www.4xshaft.com |
